Hunter Norman
- Feb 28, 2017
I had issues with this in the past and never got it resolved but now I'm having to revisit this task.
I wouldn't think this would be so hard but I've had no luck with remote access on my plex server running on FreeNas. I called my ISP, since they NAT IP addresses by default and had them remove NAT. In my netgear router settings I changed my IP from "set dynamically by ISP" to Static. I set up a port forward with all 4 ports as 32400 and my plex jail IP as the IP there. It still says it's unavailable out of my network. I'm not really sure the best way to go about this. It's a typical headless FreeNas but I have an external monitor to use the GUI. I have a netgear AC router as well, if that helps. Just the one router and fiber optic internet, no other routers/modems connected.
Any tips or suggestions are greatly appreciated.
