It appears that SCALE allows ten concurrent scrubs. I'd like to limit that to a lower number. Is there a sysctl or other way to set the specific number I want?
Yup, just checked... that's painful. Look at the links I added; there doesn't seem to be a tunable for limiting the number of concurrent scrubs on the system... Just don't schedule them in an overlapping way I guess.
Thanks. It's possible that zfs_scrub_delay will do what I want, but I don't really want the scrubs to be slower -- I just want fewer to run at once. This feels like a SCALE setting, not an OpenZFS setting.
I wound up just changing the code to limit the number of scrubs to 2. In pool_actions.py edit the line below from 10 to whatever is required (note the caveat that changing the code could hose up the middleware and require a reinstall of TrueNAS), but for me, this is much better than allowing ten concurrent scrubs:
How many pools do you have to make this an issue at all? I can't imagine more than three pools in a single system, and even that is weird edge case stuff.
I guess I’m an edge case. I have up to 50 pools for various reasons.
A key one is that I keep client data on separate pools so I can detach the pool and remove the drives to put their data into cold storage for a retention period.
