eventhorizons
- Nov 30, 2023
It appears that the length of the "Auxiliary Groups" form field is limited and cannot be longer then a specific number of characters.
Currently running TrueNAS-13.0-U5.3.
This problem was noted in the post "https://www.truenas.com/community/threads/limit-number-of-auxiliary-groups.99161/" and was marked "solved" but there does not appear to be an actual solution, other then working around it.
Has this been addressed anywhere else?
Is there a "proper" way to deal with this or do I need to do some kind of workaround or tweak the code myself?
Thanks!
Thanks!
