SnoppyFloppy
- Jun 17, 2021
I've experienced a behavior both in 21.06 and now in 21.08 which I really understand.
If I choose my ssd pool for apps storage, SCALE only create one dataset - ix-applications. But if I choose a rust pool, SCALE will create the ix-applications dataset as well as sub-datasets for each application i install.
Both pools are two-disk mirrored pools with more or less the same configuration - I think only recordsize if different between the two.
Is this by design?
I prefer the behavior of the rust scenario but I would rather have my apps installed on ssds.
EDIT: See post #2. The system DOES create datasets under ix-applications when the ssd pool is created. They just don't show up in the webUI as datasets.
Is this by design?
