Replicate apps between two servers, not scale them
Ayo91
I have two TrueNas servers and a replication task from one of the to the other one. The replication task is successull and all datasets look pretty good.
However, I would like to have the same apps in the replicated server, I dont mean scale them, only a running copy of it, so, when I am in my other home, I can run them.
The dataset that contains all app related topic is replicated too: ix-applications
However, I get this error when access to the Apps menu and link the pool (replicated server):
Failed to configure kubernetes cluster for Applications: Command '('mount', '-t', 'zfs', 'main_pool/ix-applications/k3s/kubelet', '/var/lib/kubelet')' returned non-zero exit status 1.​
Any idea how to achieve the solution?
No, you can't do that at this stage of the development... you will only be able to do that with the bluefin release which also supports scaling out apps.
Ayo91
Uohh ok, thanks for the feedback. Looking forward bluefin.
