Melrok
- Oct 20, 2023
After toying with a TrueNAS CORE installed in an old PC, I bought new hardware for a new server, but TrueNAS CORE won't install…
I tried the 13.0-U6 but it always stuck with a black screen with a white cursor. In normal console mode the last message is:
My hardware:
- ASRock H610M-ITX/ac (I don't plan to use their wifi things)
- Intel Core i3 12100 (integrated GPU)
- 2×8Gb DDR4 Lexar
- M2 250Gb PNY
- and 4 HDD of 4Tb each
- during installation there were the 8Gb usb stick and 1 usb for keyboard+mouse (the logitech in the verbose output)
I tried several OS. All TrueNAS BSD were stuck, all Linux succeed without any issues and FreeBSD proceed the installation:
- FreeNAS-11.2-U8.iso
- FreeNAS-11.3-U3.iso
- FreeNAS-11.3-U5.iso
- TrueNAS-12.0-U1.iso
- TrueNAS-13.0-U6.iso
- TrueNAS-13.1-MASTER-202311280816-a0b2df9.iso
- TrueNAS-SCALE-23.10.0.1.iso
- ubuntu-22.04.3-desktop-amd64.iso
- ubuntu-22.04.3-live-server-amd64.iso
- FreeBSD-14.0-RELEASE-amd64-bootonly.iso
I think of 3 possibles explanations:
- hardware incompatible with TrueNAS CORE, which I find strange (if it requires a separated GPU for example)
- I didn't wait enough, perhaps the installation is very slow and stuck for more than 15min for a strange reason
- I didn't configured the BIOS correctly, but even there I tried and didn't see any option to change.
Does someone have a clue?
I really prefer TrueNAS CORE over SCALE, even if I can install more tools in a Linux machine than BSD…
Dual Console: Serial Primary, Video Secondary....
Root mount waiting for: usbus0 da
da0 at umass-sim0 bus 0 scbus5 target 0 lun 0
da0: <Generic Flash Disk 8.07> Removable Direct Access SPC-2 SPC-2 SCSI device
da0: Serial Number 00B9ECCD
da0: 40.000MB/s transfers
da0: 7431MB (15218688 512 byte sectors)
da0: quirks=0x2<NO_6_BYTE>
da0: Delete methods: <NONE(*),ZERO>
GEOM: new disk da0
(da0:umass-sim0:0:0:0):PREVENT ALLOW MEDIUM REMOVAL not supported.
GEOM: da0: the secondary GPT header is not in the last LBA.
GEOM: iso9660/TRUENAS: the secondary GPT header is not in the last LBA.
ugen0.3: <Logitech USB Receiver> at usbus0
ukbd0 on uhub0
ukbd0: <Logitech USB Receiver, class 0/0, rev 2.00/29.01, addr 2> on usbus0
kbd2 at ukbd0
kbd2: ukbd0, generic (0), config:0x0, flags:0x3d0000
ums0 on uhub0
ums0: <Logitech USB Receiver, class 0/0, rev 2.00/29.01, addr 2> on usbus0
ums0: 18 buttons and [XYZT] coordinates ID=2
ugen0.4: <ASRock LED Controller> at usbus0
uhid0 on uhub0
uhid0: <ASRock LED Controller, class 0/0, rev 1.10/0.00, addr 3> on usbus0
ugen0.5: <vendor 0x8087 product 0x0aa7> at usbus0
cd9660: RockRidge Extension
md0 attached to /data/base.ufs.uzip
Trying to mount root from ufs:/dev/md0.uzip [rw]...
efirtc0: providing initial system time
start_init: trying /sbin/init
GEOM: new disk da0
ukbd0 on uhub0
kbd2 at ukbd0
ums0 on uhub0
uhid0 on uhub0
My hardware:
- 2×8Gb DDR4 Lexar
- M2 250Gb PNY
