Failed to mount to device
basket
I'm trying to create a backup server for my small business
Hardware info:
Base Board Information
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: PRIME B360M-A
Version: Rev X.0x
Serial Number: 180732516400864
Asset Tag: Default string
Features:
Board is a hosting board
Board is replaceable
Location In Chassis: Default string
Chassis Handle: 0x0003
Type: Motherboard
Contained Object Handles: 0
CPU:
Model name: Intel(R) Core(TM) i5-8400 CPU @ 2.80GHz
CPU family: 6
Model: 158
Thread(s) per core: 1
Core(s) per socket: 6
Socket(s): 1
Stepping: 10
CPU(s) scaling MHz: 31%
CPU max MHz: 4000.0000
CPU min MHz: 800.0000
BogoMIPS: 5599.85
I've mounted the iso for
TrueNAS-13.0-U4
to as USB using the lastest RufusUSB. The error I get is pictured below:
Those CAM status errors indicate there's a problem with the USB/CD boot drive, so either the ISO is corrupt or the connection is not working properly.
