Dashboard not showing replaced CPU information after Hardware upgrade
TimAM
After upgrading my Dell r510 from Single CPU E5620 to dual 5650 the dashboard doesnt update to show the new CPU info or cores.
TrueNAS-SCALE-22.02-RC.2
The RAM is showing as doubled (meaning its using both CPU) and also the below from shell shows them in operation.
Is there a way to re-scan? the CPU to update the Dashboard?
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
Address sizes: 40 bits physical, 48 bits virtual
CPU(s): 24
On-line CPU(s) list: 0-23
Thread(s) per core: 2
Core(s) per socket: 6
Socket(s): 2
NUMA node(s): 2
Vendor ID: GenuineIntel
CPU family: 6
Model: 44
Model name: Intel(R) Xeon(R) CPU X5650 @ 2.67GHz
Kris Moore
SVP of Engineering
Administrator
We'll probably need to see a debug file so we can figure out why that is showing incorrectly. Please open a ticket on https://jira.ixsystems.com with a debug attached (System -> Advanced -> Download Debug)
Thanks!
TimAM
After I'd shutdown a coupe of times I noticed it came up as expected (Previously had restarted a few times)
- So I guess all good now!
