Installationboot - KDB enter Panic
aurel81
Hey there, i am quite new to freenas. Freenas should replace the existing Ubuntu Setup, but right at the installtion - boot (either from CD 9.3 or USB 9.1.29 - i guess), i get the kdb: enter: panic error.
I am really not sure, but my hardware is
Intel i3, Zotac Z97 with 8gb ram, ocz ssd
Attaching a real "screenshot"
Maybe you can help me ?
If necessary, i could give you more hardwareinfo.
Edit: just found a thread with the same issue, where a biosupdate helped ... i gonna try it ;-)
Yeah, that message is some kind of improper hardware compatibility issue. Can't say I'm surprised as the Z97 chipset isn't exactly "recommended/compatible gear" for FreeBSD. Might get lucky with a BIOS update and you may or may not have problems in the future. Good luck in any case.
aurel81
thx :)
ok biosupdate done, installationmenu is showing up and i realised its not z97 ... its a h61 :)
hopefully i can install it no without any further problems !
H61 is just as bad. Still not a server chipset, still gonna have loads of custom manufacturer stuff and still not recommended/compatible gear.
ShinobiX9X
i got this error today for the first time, after upgrading to freenas stable 20150604.
i tried booting to 2 previous version that worked, but they don't work anymore, same error
difference with pic above, is i got pid 817 tid 100556, and also pid 819 tid 100558 (i added a picture)
anyone an idea what i should do or try?
thanks!
intel xenon
4 x 4gb ddr3 ecc ram
1 wd green and 3 wd red 3TB in zfs raidZ2
