Import ZFS pool from a FreeBSD installation
reaktor
Hello!
I plan to move from FreeBSD 10.3 to FreeNAS 9.10.
How can I use, import my "old" ZFS pool? (with geli)
Cheers!
HoneyBadger
actually does care
Administrator
reaktor
thanks for your reply.
The problem now is, that I cant import the existing pool. I imported the pool on the command line, because every disc has a seperate encryption key, which is not supported by the FreeNAS GUI.
On Step 2 of 2 in the volume import at the GUI, the dropdown is empty.
