i have try to install plugin
mullcom
hello i have try to install plugins on my nas.
i have a bug report to look at.
Her https://bugs.freenas.org/issues/6157
PLEAS help me. realy wont this to working agen.
Oct 18 09:45:01 srv-freenas smbd62554: STATUS=daemon 'smbd' finished starting up and ready to serve connectionsFailed to fetch record!
Oct 18 14:24:17 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/ping -q -t 2 -o 10.90.110.8
Oct 18 14:24:24 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/ping -q -t 2 -o 10.90.110.8
Oct 18 14:26:18 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/ping -q -t 2 -o 10.90.110.8
Oct 18 14:28:18 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/ping -q -t 2 -o 10.90.110.8
Oct 18 14:28:21 srv-freenas warden: Building new Jail... Please wait...
Oct 18 14:28:21 srv-freenas warden: zfs clone raid-z1/jail/.warden-template-pluginjail@clean raid-z1/jail/htpc-manager_1
Oct 18 14:28:22 srv-freenas warden: Success!
Oct 18 14:28:22 srv-freenas warden: Jail created at /mnt/raid-z1/jail/htpc-manager_1
Oct 18 14:28:22 srv-freenas kernel: epair1a: Ethernet address: 02:45:2d:00:0a:0a
Oct 18 14:28:22 srv-freenas kernel: epair1b: Ethernet address: 02:45:2d:00:0b:0b
Oct 18 14:28:22 srv-freenas kernel: epair1a: link state changed to UP
Oct 18 14:28:22 srv-freenas kernel: epair1b: link state changed to UP
Oct 18 14:28:22 srv-freenas kernel: epair1a: promiscuous mode enabled
Oct 18 14:28:22 srv-freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair1b
Oct 18 14:28:31 srv-freenas notifier: Performing sanity check on nginx configuration:
Oct 18 14:28:31 srv-freenas notifier: nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok
Oct 18 14:28:31 srv-freenas notifier: nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful
Oct 18 14:28:38 srv-freenas manage.py: [freeadmin.navtree:526] Couldn't retrieve http://10.90.110.6/plugins/htpc-manager/2/_s/treemenu: timed out
Oct 18 14:30:58 srv-freenas manage.py: [plugins.utils:92] Couldn't retrieve http://10.90.110.6/plugins/htpc-manager/2/_s/status: HTTP Error 504: Gateway Time-out
Oct 18 14:33:30 srv-freenas manage.py: [freeadmin.navtree:526] Couldn't retrieve http://10.90.110.6/plugins/htpc-manager/2/_s/treemenu: timed out
Ändra Bevaka Kopiera
mullcom
Whot dose this stand for?
plugins.utils:92
is that ports in the end?
joeschmuck
Old Man
You apparently have a network configuration problem. If you want help then you will need to give complete details of what steps you are taking to install a plugin and at which point the failure appears. Also provide your network setup. Do you have a static IP because DHCP is not a good solution if you are going to have jails/plugins.
mullcom
OK...
I have tried both static and DHCP. Will the same error.
Right now i have static IP
What I Do
1-login to freenas.
2--Go to plugins.
3---chose a plugin. and install.
4----wait and it take long time and then it's falling.
A jail have been created and a plugin is installed but not started. if i try start it it going to fail.
joeschmuck
Old Man
Which version of FreeNAS are you running and what is your hardware configuration (listing of hardware parts, CPU, RAM, etc...)?
I'd like to see if I can recreate your issue in a virtual machine.
joeschmuck
Old Man
So be a bit more descriptive, treat me like I'm stupid and you need to teach me how to do what you are doing. This is the only way I will be able to help you. Such as exactly which screens to click, what is happening during the installation process like the screen shows installation 1/4, etc..., and where exactly it fails.
Also, where is your jail created and how much hard drive space do you have for the jail?
mullcom
ok.
Hardware configuration
Memory: 8152MB
CPU: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz
Disk: raid-z1 6.7 gig available
the lates vertion. but its appers in the yealy vertions to.
System: FreeNAS-9.2.1.8-RELEASE-x64 (e625626)
joeschmuck
Old Man
I am currently using just DHCP to see how it works and Couchpotato since that was in your example. I don't use it so this will be a first for me. I do use Plex and MiniDLNA. It sure is taking a long time to create the template.
Also, which plugins have you tried? Did you get any to work?
mullcom
ok...
The problem start after i Fixing with my networks setup.
i wose then in 9.2.1.6-RC2 realise....
after trying to fix the problem with no lock i upgrade to freenas. 9.2.7
and later on i go to FreeNAS-9.2.1.8-RELEASE-x64 (e625626)
and still this problem.
Networks settings.
link aggrigation. (lagg0)
https://docs.google.com/a/toit.se/file/d/0B0ghzSSUOQH8NEhyeXFPLTc2RkE/edit?usp=drivesdk
PLUGIN PROBLEM
installing Plugin
problem to creat jails under plugins installations.
it go to (3/4) Creating jail 50% and stand ther a long time.
then i get the failing messege. but jail have been creatid and plugin is installd but offline
i dont see the plugin in the right tree list under plugins.
but if i wate one h or so it comes up and some off the plugin can i start if i go to install plugins and try to start it. https://docs.google.com/a/toit.se/file/d/0B0ghzSSUOQH8WnZMYkc0bkRNcnM/edit?usp=drivesdk
Plugin this happen on = ALL
same faling process.
Oct 18 19:33:44 srv-freenas manage.py: [freeadmin.navtree:526] Couldn't retrieve http://10.90.110.6/plugins/couchpotato/3/_s/treemenu: timed out
Oct 18 19:43:46 srv-freenas manage.py: [freeadmin.navtree:526] Couldn't retrieve http://10.90.110.6/plugins/couchpotato/3/_s/treemenu: timed out
Oct 18 19:47:16 srv-freenas manage.py: [plugins.utils:92] Couldn't retrieve http://10.90.110.6/plugins/couchpotato/3/_s/status: HTTP Error 504: Gateway Time-out​
sometime it take long time to reache installd plugin list.
mullcom
i update the post 11
joeschmuck
Old Man
Please post the results of ifconfig. Also under the Jails Configuration, what is the starting IP address for your jails? Does the results make sense to you and are they okay for your network configuration?
I was not able to install couchpotato but was able to install MiniDLNA using DHCP. Now I will change to a static IP, Subnet, DNS, and Gateway and try couchpotato again.
mullcom
https://docs.google.com/a/toit.se/file/d/0B0ghzSSUOQH8dXpmcjNnM0lja1E/edit?usp=drivesdk
I dont find the gateway ?
mullcom
This is whot i got if i disable jail and renabel it agen
Oct 18 21:18:17 srv-freenas kernel: epair2a: link state changed to DOWN
Oct 18 21:18:17 srv-freenas kernel: epair2b: link state changed to DOWN
Oct 18 21:18:27 srv-freenas notifier: Performing sanity check on nginx configuration:
Oct 18 21:18:27 srv-freenas notifier: nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok
Oct 18 21:18:27 srv-freenas notifier: nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful
Oct 18 21:18:28 srv-freenas kernel: epair2a: Ethernet address: 02:20:e4:00:0b:0a
Oct 18 21:18:28 srv-freenas kernel: epair2b: Ethernet address: 02:20:e4:00:0c:0b
Oct 18 21:18:28 srv-freenas kernel: epair2a: link state changed to UP
Oct 18 21:18:28 srv-freenas kernel: epair2b: link state changed to UP
Oct 18 21:18:28 srv-freenas kernel: epair2a: promiscuous mode enabled
Oct 18 21:18:28 srv-freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair2b
Oct 18 21:18:38 srv-freenas manage.py: [freeadmin.navtree:526] Couldn't retrieve http://10.90.110.6/plugins/couchpotato/3/_s/treemenu: timed out
joeschmuck
Old Man
I have confirmed that 9.2.1.7 will install couchpotato without issue however 9.2.1.8 I am unable to install it completely.
mullcom
i have try plexmediaserver
Oct 19 22:47:31 srv-freenas notifier: Performing sanity check on nginx configuration:
Oct 19 22:47:31 srv-freenas notifier: nginx: the configuration file /usr/local/etc/nginx/nginx.conf syntax is ok
Oct 19 22:47:31 srv-freenas notifier: nginx: configuration file /usr/local/etc/nginx/nginx.conf test is successful
Oct 19 22:47:38 srv-freenas manage.py: [freeadmin.navtree:526] Couldn't retrieve http://10.90.110.6/plugins/plexmediaserver/4/_s/treemenu: timed out
Oct 19 22:48:37 srv-freenas manage.py: [plugins.utils:92] Couldn't retrieve http://10.90.110.6/plugins/plexmediaserver/4/_s/status: HTTP Error 504: Gateway Time-out
Oct 19 22:52:19 srv-freenas manage.py: [plugins.utils:92] Couldn't retrieve http://10.90.110.6/plugins/plexmediaserver/4/_s/status: HTTP Error 504: Gateway Time-out
mullcom
https://docs.google.com/a/toit.se/file/d/0B0ghzSSUOQH8SGxOWkxvOEQ2Y0k/edit?usp=drivesdk
No gateway?
I add gateway and then go to install plugins. and i get this
Oct 19 23:03:28 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs list -H -o name /mnt/raid-z1/jail/.warden-template-pluginjail
Oct 19 23:03:28 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs get -H origin /mnt/raid-z1/jail/couchpotato_1
Oct 19 23:03:28 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs get -H origin /mnt/raid-z1/jail/plexmediaserver_1
Oct 19 23:03:28 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs get -H origin /mnt/raid-z1/jail/transmission_1
Oct 19 23:03:28 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs get -H origin /mnt/raid-z1/jail/htpc-manager_1
Oct 19 23:03:28 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs list -H -o name /mnt/raid-z1/jail/.warden-template-linux-ubuntu-12.04.tgz
Oct 19 23:03:29 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs get -H origin /mnt/raid-z1/jail/couchpotato_1
Oct 19 23:03:29 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs get -H origin /mnt/raid-z1/jail/plexmediaserver_1
Oct 19 23:03:29 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs get -H origin /mnt/raid-z1/jail/transmission_1
Oct 19 23:03:29 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs get -H origin /mnt/raid-z1/jail/htpc-manager_1
Oct 19 23:03:29 srv-freenas manage.py: [common.pipesubr:58] Popen()ing: /sbin/zfs list -H -o name /mnt/raid-z1/jail/.warden-template-linux-mint-13
mullcom
Oct 19 23:38:30 srv-freenas kernel: ng_ether_ifnet_arrival_event: can't re-name node epair1b
Oct 19 23:38:30 srv-freenas kernel: arp: 02:a9:c6:00:0a:0a is using my IP address 10.90.110.9 on epair1b!
Oct 19 23:38:30 srv-freenas kernel: arp: f2:f4:6f:00:0a:0b attempts to modify permanent entry for 10.90.110.9 on lagg0
Oct 19 23:38:34 srv-freenas manage.py: [freeadmin.navtree:526] Couldn't retrieve http://10.90.110.6/plugins/couchpotato/3/_s/treemenu: HTTP Error 502: Bad Gateway
