Hello!
First of all, I want to say thank you
@online2 for starting this thread and sharing a possible solution!! Thank you, so, so much!
As many others, one day I turned off my truenas with the asrock c2750d4i, and then, it didn't want to start up again. Which led me to this thread :)
The original solution explained here worked like a charm for me. I connected the resistors and wires as described, and the motherboard was alive again. Though, it didn't last long. After 2 months, I had to power off the computer again, and it didn't want to start again.
The symptoms were exactly the same after removing the connection to the PCICLK pin. However, if I reconnected everything, the motherboard didn't even turn on. I could hear the fan for like a few milliseconds, and the power light blinking but it automatically powered off. After further inspection with the multi-meter, I discovered that the 3V pin wasn't providing any voltage anymore. Not sure if it has been burned in the process, but yeah, it looks dead :(
So, then I decided to try a different thing. Got myself a cheap voltage regulator (
this to be precise). I connected the input to one of the spare PCI-E connector (like the one in this
image, bottom right, 4 pins) that I am not using, which produces a voltage of 12V. Then, I used the voltage regulator to lower it to 3.3V. It still didn't want to start up. HOWEVER, it DID start when I increase the voltage up to 3.33V, which I guess might make sense since I've used longer wires during my testing that I had before.
One thing though, it doesn't start if I am supplying the voltage from the start. I have to first disconnect everything, then, start the compute, wait like 10 seconds, and then, activate the 3.33V power supply to the PCICLK pin.
So at the end, I've changed the BIOS setting so the computer doesn't start up automatically in the event of a power loss, and I've added a switch between the voltage regulator and the PCICLK pin, so I can easily start up the computer, wait for a few seconds, and then, switch on the power to the PCICLK.
This setup is currently working and the server starts up every single time
I am not sure if this will end burning any other part of the motherboard. BIOS and IPMI interfaces says all sensors are green, and CPU / Memory usage seems normal. Also, the computer is not overheating or doing anything weird. The PCICLK is consuming around 120mA constantly (+/- 5). Of course, if I disconnect the PCICLK power, the computer freezes completely
I will start looking for a different motherboard. I don't think I can trust this one anymore, but just wanted to write here my findings in case it's useful for anyone. Though remember, try this at your own risk :)
Thank you very much!
