SOLVED Help unable to import pool logs device unavailable
AVSION
Hi Guys,
I did a big mistake was trying to relocate the SWAP/SLOG/A2ARC SSD to intel Optane 900p SSD PCIe, i formate the existing SWAP/SLOG/A2ARC SSD before relocating it to the 900p. now i can't import the pool "Tank, i get an error that the pool is unavailable due to the log device is missing. using gpart i already created the partitions and relocated the swap to the 900p but as the pool is not imported i cant relocated the SLOG/A2ARC see below printout. all the drives show online and i didn't delete the pool only format the previous SWAP/SLOG/A2ARC SSD. how can i import the pool when the SLOG/A2ARC is missing?? Please help.
Note - all my system info is in my signature, and i'm not using ESXi at the moment, i booted bare-metal from usb to fix the pool issue.
Thank you
[root@freenas ~]# glabel status | grep nvd0
gptid/6762c737-c0a1-11e8-9f75-0cc47adb3218	 N/A  nvd0p1
gptid/6ff84a55-c0a1-11e8-9f75-0cc47adb3218	 N/A  nvd0p2
gptid/76d01ebd-c0a1-11e8-9f75-0cc47adb3218	 N/A  nvd0p3
[root@freenas ~]# swapinfo
Device		  512-blocks	 Used	Avail Capacity
/dev/gptid/6762c737-c0a1-11e8-9   33554432		0 33554432	 0%
[root@freenas ~]# zpool add Tank log gptid/6ff84a55-c0a1-11e8-9f75-0cc47adb3218
cannot open 'Tank': no such pool
[root@freenas ~]# zpool import
   pool: Tank
  state: UNAVAIL
 status: The pool was last accessed by another system.
 action: The pool cannot be imported due to damaged devices or data.
   see: http://illumos.org/msg/ZFS-8000-EY
		Tank											UNAVAIL  missing device
		  raidz2-0									  ONLINE
			gptid/b5b40bb4-4e99-11e7-9cba-0cc47adb3218  ONLINE
			gptid/b69faf01-4e99-11e7-9cba-0cc47adb3218  ONLINE
			gptid/b792e7b8-4e99-11e7-9cba-0cc47adb3218  ONLINE
			gptid/b87cfa92-4e99-11e7-9cba-0cc47adb3218  ONLINE
			gptid/b969428a-4e99-11e7-9cba-0cc47adb3218  ONLINE
			gptid/ba5cf8b5-4e99-11e7-9cba-0cc47adb3218  ONLINE
			gptid/bb4ae668-4e99-11e7-9cba-0cc47adb3218  ONLINE
			gptid/bc3d4265-4e99-11e7-9cba-0cc47adb3218  ONLINE
		logs
		  2473847764174423671						   UNAVAIL  cannot open
[root@freenas ~]# zpool status Tank
  pool: freenas-boot
 state: ONLINE
  scan: none requested
		NAME		STATE	 READ WRITE CKSUM
		freenas-boot  ONLINE	   0	 0	 0
		  da8p2	 ONLINE	   0	 0	 0
errors: No known data errors
That's easy, zpool import -m poolname. Of course, you will lose any transactions that were in ZIL but had not yet been committed to disk.
AVSION
Thanks Ericloewe you made my day:) see below
i already created the new SLOG/A2ARC partitions and attached them but I just have the old log still there how do i get rid-off it? i clicked scrub and its doing it right now is that will clean it?
Thanks again
root@freenas:~ # zpool import -m Tank
cannot import 'Tank': pool may be in use from other system, it was last accessed by  (hostid: 0xc0d18754) on Mon Sep 24 17:54:38 2018
use '-f' to import anyway
   pool: Tank
  state: UNAVAIL
		 raidz2-0									  ONLINE
	   logs
root@freenas:~ # zpool import -f Tank
The devices below are missing or corrupted, use '-m' to import the pool anyway:
		   gptid/7de19854-b8fa-11e8-8abb-000c29ab00cc [log]
cannot import 'Tank': one or more devices is currently unavailable
root@freenas:~ # zpool import -m -f Tank
root@freenas:~ # zpool status
  pool: Tank
 state: DEGRADED
status: One or more devices could not be opened.  Sufficient replicas exist for
	   the pool to continue functioning in a degraded state.
action: Attach the missing device and online it using 'zpool online'.
   see: http://illumos.org/msg/ZFS-8000-2Q
  scan: resilvered 6.54M in 0 days 00:00:01 with 0 errors on Thu Sep 13 10:31:14 2018
	   Tank											DEGRADED	 0	 0	 0
		 raidz2-0									  ONLINE	   0	 0	 0
		   gptid/b5b40bb4-4e99-11e7-9cba-0cc47adb3218  ONLINE	   0	 0	 0
		   gptid/b69faf01-4e99-11e7-9cba-0cc47adb3218  ONLINE	   0	 0	 0
		   gptid/b792e7b8-4e99-11e7-9cba-0cc47adb3218  ONLINE	   0	 0	 0
		   gptid/b87cfa92-4e99-11e7-9cba-0cc47adb3218  ONLINE	   0	 0	 0
		   gptid/b969428a-4e99-11e7-9cba-0cc47adb3218  ONLINE	   0	 0	 0
		   gptid/ba5cf8b5-4e99-11e7-9cba-0cc47adb3218  ONLINE	   0	 0	 0
		   gptid/bb4ae668-4e99-11e7-9cba-0cc47adb3218  ONLINE	   0	 0	 0
		   gptid/bc3d4265-4e99-11e7-9cba-0cc47adb3218  ONLINE	   0	 0	 0
	   logs
		 2473847764174423671						   UNAVAIL	  0	 0	 0  was /dev/gptid/7de19854-b8fa-11e8-8abb-000c29ab00cc
  pool: freenas-boot
 state: ONLINE
		 da8p2	 ONLINE	   0	 0	 0
root@freenas:~ # glabel status | grep nvd0
root@freenas:~ # zpool add tank log gptid/6ff84a55-c0a1-11e8-9f75-0cc47adb3218
cannot open 'tank': no such pool
root@freenas:~ # zpool add Tank log gptid/6ff84a55-c0a1-11e8-9f75-0cc47adb3218
root@freenas:~ # zpool add Tank cache gptid/76d01ebd-c0a1-11e8-9f75-0cc47adb3218
root@freenas:~ #
root@freenas:~ #
root@freenas:~ #
root@freenas:~ #
root@freenas:~ #
root@freenas:~ # zpool status tank
root@freenas:~ # zpool status Tank
  pool: Tank
 state: DEGRADED
	   Tank											DEGRADED	 0	 0	 0
	   logs
		 gptid/6ff84a55-c0a1-11e8-9f75-0cc47adb3218	ONLINE	   0	 0	 0
	   cache
		 gptid/76d01ebd-c0a1-11e8-9f75-0cc47adb3218	ONLINE	   0	 0	 0
HoneyBadger
actually does care
Administrator
You should be able to remove the old (UNAVAIL) log device from the GUI.
Or zpool remove, which removes vdevs in general.*
*Restrictions apply
AVSION
Thanks guys all back to normal all the best
