Here is a synch on, compression off, record size 16K test after BIOS changes.
		Auto Mode
		File size set to 524288 kB
		OPS Mode. Output is in operations per second.
		Command line used: iozone -a -s 512M -O
		Time Resolution = 0.000001 seconds.
		Processor cache size set to 1024 kBytes.
		Processor cache line size set to 32 bytes.
		File stride size set to 17 * record size.
															  random	random	 bkwd	record	stride
			  kB  reclen	write  rewrite	read	reread	read	 write	 read   rewrite	  read   fwrite frewrite	fread  freread
		  524288	   4	22088	22649   345977   342938   277856	18634   298145	 25845	247717	23279	22625   320338   316925
		  524288	   8	18699	19555   281264   272460   242009	17761   206286	 23760	213098	19425	19356   233624   238386
		  524288	  16	15348	15311   142649   132718   152798	15498   141504	 20491	152915	15551	15385   118293   109392
		  524288	  32	10823	10406	90298	90522   114350	10276	89425	 12824	110196	10967	10813	53241	66468
		  524288	  64	 6201	 6645	32870	44692	51955	 6456	33437	  7493	 32527	 6689	 6839	22839	36163
		  524288	 128	 3670	 3278	31965	31649	33708	 4043	18890	  4399	 20291	 3902	 3468	22593	27468
		  524288	 256	 2405	 2294	18718	18144	12339	 2141	17493	  2905	  7460	 2240	 2587	 5758	 8761
		  524288	 512	 1279	 1477	 4045	 6601	 7280	 1286	 8687	  1735	  4162	 1275	 1459	 3182	 4639
		  524288	1024	  665	  780	 1850	 2972	 3821	  679	 4494	   988	  5915	  596	  732	 2969	 3518
		  524288	2048	  360	  323	 2113	 2107	 2116	  332	 1545	   421	  1765	  374	  315	 1375	 1422
		  524288	4096	  183	  146	  985	  917	 1005	  191	 1472	   202	   441	  168	  160	  582	  609
		  524288	8192	   85	   79	  416	  404	  396	   92	  485		92	   238	   82	   95	  149	  159
		  524288   16384	   43	   38	  178	  169	  181	   47	  234		45		92	   43	   38	   98	   97
iozone test complete.
Here is a synch off, compression off, record size 16K test after BIOS changes.
		Auto Mode
		  524288	   4   111667   119149   336434   347803   194594	89076   315069	148233	208375   122403   115359   317707   232941
		  524288	   8	78859   112411   182790   215608   177820	88411   164612	141886	148604	98523	95586   271420   190667
		  524288	  16	73804	84856   191229   178865   177511	74686   124422	128961	140550	76393	94896	96863   143167
		  524288	  32	38349	46196   121239   130260   117580	32701   115528	 73278	109846	47612	48851   103936	52042
		  524288	  64	20680	23983	62043	63506	61935	25529	46832	 39234	 46402	20836	24014	49599	53224
		  524288	 128	11023	13405	36126	15906	26491	10563	34033	 18418	 33484	12899	 9482	23033	22362
		  524288	 256	 5363	 6196	18120	17969	18810	 6360	 9371	  9585	 14186	 5563	 6279	12577	14723
		  524288	 512	 2937	 2996	10242	11794	11139	 2227	 8641	  4761	  9018	 3200	 3163	 7446	 5888
		  524288	1024	 1363	 1577	 4483	 4060	 4658	 1561	 4471	  2846	  3524	 1172	 1572	 3127	 3236
		  524288	2048	  658	  917	 3092	 2089	  963	  682	 2236	  1140	  2291	  804	  857	 1784	  762
		  524288	4096	  332	  376	 1022	 1045	 1022	  384	  550	   497	   654	  340	  390	  717	  913
		  524288	8192	  167	  136	  395	  397	  410	  182	  413	   211	   221	  156	  182	  217	  208
		  524288   16384	   82	   72	  176	  178	  188	  108	  103		90	   120	   79	   88	   70	   74
