HELP needed -> SCSI sense: NOT READY -> pool lost
IceBoosteR
Hi all,
first of all my system config:
Xeon E3-1225v3 on Dell T20 motherboard
24GB of DD3 ECC memory
10x4TB WD RED in RAIDZ2 connected 8drives via flashed M1015 and 2 drives via onbaord SATA.
Seasonic Focus Plus Platinum 650W with APC Back UPS Pro 900VA in front of the system.
Today I am getting this error messages:
CRITICAL: May 20, 2018, 11:09 a.m. - The volume RED state is DEGRADED: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state.
Seeing in zpool status:
root@freenas:~ # zpool status
  pool: RED
 state: DEGRADED
status: One or more devices are faulted in response to persistent errors.
		degraded state.
action: Replace the faulted device, or use 'zpool clear' to mark the device
		repaired.
  scan: scrub repaired 0 in 0 days 05:10:32 with 0 errors on Sun May 20 05:10:58 2018
		NAME												STATE	 READ WRITE CKSUM
		RED												 DEGRADED	 0	 0	 0
		  raidz2-0										  DEGRADED	 0	 0	 0
			gptid/5575c4d7-b72f-11e7-96c3-1866da308b0d.eli  ONLINE	   0	 0	 0
			gptid/c7c9cba9-cd27-11e7-b158-1866da308b0d.eli  ONLINE	   0	 0	 0
			gptid/56f73609-b72f-11e7-96c3-1866da308b0d.eli  ONLINE	   0	 0	 0
			gptid/ee2f1174-1e6f-11e8-84e7-1866da308b0d.eli  ONLINE	   0	 0	 0
			gptid/5881e2ae-b72f-11e7-96c3-1866da308b0d.eli  ONLINE	   0	 0	 0
			gptid/593ba0f5-b72f-11e7-96c3-1866da308b0d.eli  ONLINE	   0	 0	 0
			gptid/59f5e3ca-b72f-11e7-96c3-1866da308b0d.eli  ONLINE	   0	 0	 0
			gptid/5aaf3ccd-b72f-11e7-96c3-1866da308b0d.eli  ONLINE	   0	 0	 0
			gptid/5c015dd6-b72f-11e7-96c3-1866da308b0d.eli  FAULTED	  0   601	 0  too many errors
			gptid/5cc902e2-b72f-11e7-96c3-1866da308b0d.eli  ONLINE	   0	 0	 0
errors: No known data errors
So I was running a scrub this night, which finished after 5 hours (0-5 o'clock). At 11am I am getting the error messages in /var/log/messages:
May 20 11:09:02 freenas		 (da4:mps0:0:6:0): WRITE(10). CDB: 2a 00 eb 15 9b a8 00 00 20 00 length 16384 SMID 347 terminated ioc 804b loginfo 31110630 scsi 0 state c xfer 0
May 20 11:09:02 freenas (da4:mps0:0:6:0): CAM status: CCB request completed with an error
May 20 11:09:02 freenas (da4:mps0:0:6:0): Retrying command
May 20 11:09:02 freenas (da4:mps0:0:6:0): CAM status: SCSI Status Error
May 20 11:09:02 freenas (da4:mps0:0:6:0): SCSI status: Check Condition
May 20 11:09:02 freenas (da4:mps0:0:6:0): SCSI sense: NOT READY asc:4,0 (Logical unit not ready, cause not reportable)
May 20 11:09:02 freenas (da4:mps0:0:6:0): Retrying command (per sense data)
May 20 11:09:02 freenas (da4:mps0:0:6:0): Error 5, Retries exhausted
May 20 11:09:02 freenas (da4:mps0:0: 6:0): Retrying command (per sense data)
May 20 11:09:04 freenas GEOM_ELI: g_eli_read_done() failed (error=5) gptid/5c015dd6-b72f-11e7-96c3-1866da308b0d.eli[READ(offset=0, length=4096)]
###This came up a lot of times... ####
May 20 11:09:41 freenas mps0: mpssas_prepare_remove: Sending reset for target ID 6
May 20 11:09:41 freenas da4 at mps0 bus 0 scbus0 target 6 lun 0
May 20 11:09:41 freenas da4: <ATA WDC WD40EFRX-68N 0A82> s/n WD-WCC7K3PD4PNF detached
May 20 11:09:41 freenas mps0: Unfreezing devq for target ID 6
May 20 11:09:41 freenas GEOM_MIRROR: Device swap3: provider da4p1 disconnected.
May 20 11:09:41 freenas GEOM_ELI: Device gptid/5c015dd6-b72f-11e7-96c3-1866da308b0d.eli destroyed.
May 20 11:09:41 freenas (da4:mps0:0:6:0): Periph destroyed
May 20 11:09:43 freenas mps0: SAS Address for SATA device = 4f656150bab0d586
May 20 11:09:43 freenas mps0: SAS Address from SATA device = 4f656150bab0d586
May 20 11:09:43 freenas da4 at mps0 bus 0 scbus0 target 6 lun 0
May 20 11:09:43 freenas da4: <ATA WDC WD40EFRX-68N 0A82> Fixed Direct Access SPC-4 SCSI device
May 20 11:09:43 freenas da4: Serial Number WD-WCC7K3PD4PNF
May 20 11:09:43 freenas da4: 600.000MB/s transfers
May 20 11:09:43 freenas da4: Command Queueing enabled
May 20 11:09:43 freenas da4: 3815447MB (7814037168 512 byte sectors)
May 20 11:09:43 freenas da4: quirks=0x8<4K>
SMARTCTL looks good for da4:
root@freenas:~ # smartctl -a /dev/da4
smartctl 6.6 2017-11-05 r4594 [FreeBSD 11.1-STABLE amd64] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Western Digital Red
Device Model:	 WDC WD40EFRX-68N32N0
Serial Number:	WD-WCCXXXXXXXXXXX
LU WWN Device Id: 5 0014ee 20f14a93b
Firmware Version: 82.00A82
User Capacity:	4,000,787,030,016 bytes [4.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5400 rpm
Form Factor:	  3.5 inches
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:	Sun May 20 23:30:37 2018 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
										was never started.
Self-test execution status:	  (   0) The previous self-test routine completed
										been run.
data collection:				(44400) seconds.
capabilities:					(0x7b) SMART execute Offline immediate.
										command.
										Self-test supported.
SMART capabilities:			(0x0003) Saves SMART data before entering
										power-saving mode.
Error logging capability:		(0x01) Error logging supported.
Short self-test routine
recommended polling time:		(   2) minutes.
Extended self-test routine
recommended polling time:		( 471) minutes.
Conveyance self-test routine
recommended polling time:		(   5) minutes.
SCT capabilities:			  (0x303d) SCT Status supported.
										SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x002f   200   200   051	Pre-fail  Always	   -	   0
  3 Spin_Up_Time			0x0027   161   161   021	Pre-fail  Always	   -	   6950
  4 Start_Stop_Count		0x0032   100   100   000	Old_age   Always	   -	   16
  5 Reallocated_Sector_Ct   0x0033   200   200   140	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x002e   100   253   000	Old_age   Always	   -	   0
  9 Power_On_Hours		  0x0032   095   095   000	Old_age   Always	   -	   3699
 10 Spin_Retry_Count		0x0032   100   253   000	Old_age   Always	   -	   0
 11 Calibration_Retry_Count 0x0032   100   253   000	Old_age   Always	   -	   0
 12 Power_Cycle_Count	   0x0032   100   100   000	Old_age   Always	   -	   16
192 Power-Off_Retract_Count 0x0032   200   200   000	Old_age   Always	   -	   14
193 Load_Cycle_Count		0x0032   200   200   000	Old_age   Always	   -	   1677
194 Temperature_Celsius	 0x0022   121   117   000	Old_age   Always	   -	   29
196 Reallocated_Event_Count 0x0032   200   200   000	Old_age   Always	   -	   0
197 Current_Pending_Sector  0x0032   200   200   000	Old_age   Always	   -	   0
198 Offline_Uncorrectable   0x0030   100   253   000	Old_age   Offline	  -	   0
199 UDMA_CRC_Error_Count	0x0032   200   200   000	Old_age   Always	   -	   0
200 Multi_Zone_Error_Rate   0x0008   200   200   000	Old_age   Offline	  -	   0
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline	   Completed without error	   00%	  3586		 -
# 2  Short offline	   Completed without error	   00%	  3466		 -
# 3  Short offline	   Completed without error	   00%	  3346		 -
# 4  Extended offline	Completed without error	   00%	  3238		 -
# 5  Short offline	   Completed without error	   00%	  3226		 -
# 6  Short offline	   Completed without error	   00%	  3106		 -
# 7  Short offline	   Completed without error	   00%	  2986		 -
# 8  Short offline	   Completed without error	   00%	  2866		 -
# 9  Short offline	   Completed without error	   00%	  2747		 -
#10  Short offline	   Completed without error	   00%	  2627		 -
#11  Extended offline	Completed without error	   00%	  2518		 -
#12  Short offline	   Completed without error	   00%	  2507		 -
#13  Short offline	   Completed without error	   00%	  2483		 -
#14  Short offline	   Completed without error	   00%	  2363		 -
#15  Short offline	   Completed without error	   00%	  2244		 -
#16  Short offline	   Completed without error	   00%	  2114		 -
#17  Extended offline	Completed without error	   00%	  2005		 -
#18  Short offline	   Completed without error	   00%	  1994		 -
#19  Short offline	   Completed without error	   00%	  1922		 -
#20  Short offline	   Completed without error	   00%	  1809		 -
#21  Short offline	   Completed without error	   00%	  1689		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
So basically my question is:
How to proceed?
Should I restart the server?
Offline the disks and replace it?
Poweroff and check cable?
How can this happen? :O
I haven't touched the server for days, I literally did not touch the server :D
Thanks for any quick help :)
kdragon75
If ZFS is reporting write errors, I beleve it's because the disk wrote bad data. Odds of a cable going bad and ONLY causing write errors seem kinda slim. I would offline the drive and replace it.
Drives just fail. They don't ask permission first and they don't ask for forgiveness later.:rolleyes:
kdragon75
On the smart tests, they dont test writes, just everything else non-destructive.
IceBoosteR
Thank you for your answer.
Yes I had two dying disks before, but they were slowly failing with SMART reporting errors, not ZFS.
In this case ZFS wants to access the disk, but hte disks said no.
I hope so, that the controller or cable is ok.
IceBoosteR
On the smart tests, they don't test writes, just everything else non-destructive.
So in fact, replacing the drive is the best idea now?
If the drive is the cause, I will never buy REDs again. Hello Seagate Ironwolf ...
Just need to check if I can RMA the drive without SMART errors.
kdragon75
You could try swapping drives around. It COULD be a controller but thats much less common. It's not too surprising that ZFS would catch something before smart.
IceBoosteR
Yes I could, but probably that not the best way of determine the errors/root cause. I think the best way is to swap the drive (have always one spare available) and observe if any other will be reported on the system. If not, then the disk was faulty, if yes then baaaaaaaaad. Very baaaaaad :D
I can try to run a badblock test with the drive on another system. Maybe I can see more and have a reson for RMA.
Stux
Cause is either
1) cable
2) port
3) disk
4) Power
The right diagnostic approach is to swap data cables between the ‘faulty’ drive and another.
If problem stays with drive it was the drive. Time to replace drive
If problem moves it was the port or cable, then you replace the cable because cables are cheap. If it’s the port then you’re sol, and either RMA the board, or ignore the port going forward.
And psu issues are the hardest to diagnose.
IceBoosteR
Cause is either
1) cable
2) port
3) disk
4) Power
If problem moves it was the port or cable, the. You replace the cable because cables are cheap.
Good point.
But now I have offlined the disk. How could I put the disks back to the array?
After that I can try out to swap cables I guess.
Please advice how to proceed now Sir ;)
Stux
There should be a GUI button to online the disk I believe.
IceBoosteR
No, checked that. Only "replace" is available.
Stux
You can online in the command line.
I think I may have reported a bug about that.
IceBoosteR
I will check that.
On the other hand I can replace da4 with da4. But is that is a good idea? I think its not.
IceBoosteR
IceBoosteR
Not working ...
root@freenas:/var/log # zpool online RED gptid/5c015dd6-b72f-11e7-96c3-1866da308b0d.eli
warning: device 'gptid/5c015dd6-b72f-11e7-96c3-1866da308b0d.eli' onlined, but remains in faulted state
use 'zpool replace' to replace devices that are no longer present
root@freenas:/var/log # zpool status
  pool: RED
 state: DEGRADED
status: One or more devices could not be opened.  Sufficient replicas exist for
action: Attach the missing device and online it using 'zpool online'.
   see: http://illumos.org/msg/ZFS-8000-2Q
		RED												 DEGRADED	 0	 0	 0
			5217968670663961470							 UNAVAIL	  0   601	 0  was /dev/gptid/5c015dd6-b72f-11e7-96c3-1866da308b0d.eli
IceBoosteR
Rebooted the system, disk is still unavailable.
I will replace it now.
kdragon75
Yeah ZFS is not liking your drive!
IceBoosteR
MrToddsFriends
Documentation Browser
While I can't help with your current zpool online / replace problem, did you ever consider a HBA heat problem as the cause of your issue ("CAM status: CCB request completed with an error") as reported in your initial posting?
See also the very informative discussion in
https://forums.freenas.org/index.php?threads/cooling-for-a-dell-perc-h310.61941/
This is just an addition to Stux' cable, port, disk, Power listing posted above.
IceBoosteR
no I have never thought about that one. I will add this to my option list. The CCB error was the very first one. After that I only see the "Not Ready" error. I have 4 intake fans, which should keep the system cool. Nevertheless, they are only running at 40%, due to the noise they produce. After my homeproject is finished, I move the server and can use 75% if I would like.
~added to list of things to check.
Now I will start with the resilvering.
With my test system (no ECC memory, AMD APU - should do what I need to do) I will run badblocks and another smart test.
And I will observe my mainsystem of course.
