HDD falling out of pool?
tfran1990
I have only seen this happen one time so far, to me it seems like the disk has fell out of the pool.
i also see a CAM error.
should i replace the drive?
Apr 14 01:14:01 freenas da5 at mps0 bus 0 scbus0 target 9 lun 0
Apr 14 01:14:01 freenas da5: <ATA WDC WD20EZAZ-00G 0A80> s/n WD-WXP1AC82RNH9 detached
Apr 14 01:14:01 freenas     (da5:mps0:0:9:0): ATA COMMAND PASS THROUGH(16). CDB: 85 0d 06 00 01 00 01 00 00 00 00 00 00 40 06 00 length 512 SMID 408 terminated ioc 804b loginfo 31110d00 scsi 0 state c xfer 0
Apr 14 01:14:01 freenas     (da5:mps0:0:9:0): WRITE(10). CDB: 2a 00 41 32 da 28 00 00 08 00 length 4096 SMID 815 terminated ioc 804b loginfo 31110d00 scs(da5:mps0:0:9:0): ATA COMMAND PASS THROUGH(16). CDB: 85 0d 06 00 01 00 01 00 00 00 00 00 00 40 06 00
Apr 14 01:14:01 freenas i 0 state c xfer 0
Apr 14 01:14:01 freenas (da5:mps0:0:9:0): CAM status: CCB request completed with an error
Apr 14 01:14:01 freenas (da5:mps0:0:9:0): Error 5, Periph was invalidated
Apr 14 01:14:01 freenas mps0: Unfreezing devq for target ID 9
Apr 14 01:14:01 freenas GEOM_MIRROR: Device swap0: provider da5p1 disconnected.
Apr 14 01:14:02 freenas ZFS: vdev state changed, pool_guid=6363471716941292545 vdev_guid=17276462857189123742
Apr 14 01:14:02 freenas (da5:mps0:0:9:0): Periph destroyed
Apr 14 01:14:03 freenas ZFS: vdev state changed, pool_guid=6363471716941292545 vdev_guid=17276462857189123742
Apr 14 01:14:06 freenas mps0: SAS Address for SATA device = 456f3f37ecefbf75
Apr 14 01:14:06 freenas mps0: SAS Address from SATA device = 456f3f37ecefbf75
Apr 14 01:14:06 freenas da5 at mps0 bus 0 scbus0 target 9 lun 0
Apr 14 01:14:06 freenas da5: <ATA WDC WD20EZAZ-00G 0A80> Fixed Direct Access SPC-4 SCSI device
Apr 14 01:14:06 freenas da5: Serial Number WD-WXP1AC82RNH9
Apr 14 01:14:06 freenas da5: 600.000MB/s transfers
Apr 14 01:14:06 freenas da5: Command Queueing enabled
Apr 14 01:14:06 freenas da5: 1907729MB (3907029168 512 byte sectors)
Apr 14 01:14:06 freenas ZFS: vdev state changed, pool_guid=6363471716941292545 vdev_guid=14954804824692267039
Apr 14 01:14:06 freenas ZFS: vdev state changed, pool_guid=6363471716941292545 vdev_guid=8134557650828204655
Apr 14 01:14:06 freenas ZFS: vdev state changed, pool_guid=6363471716941292545 vdev_guid=17276462857189123742
Apr 14 01:14:06 freenas ZFS: vdev state changed, pool_guid=6363471716941292545 vdev_guid=4624288917331818763
Apr 14 01:14:06 freenas ZFS: vdev state changed, pool_guid=6363471716941292545 vdev_guid=3004686278740164286
Apr 14 01:14:15 freenas mps0: mpssas_prepare_remove: Sending reset for target ID 9
Apr 14 01:14:15 freenas da5 at mps0 bus 0 scbus0 target 9 lun 0
Apr 14 01:14:15 freenas da5: <ATA WDC WD20EZAZ-00G 0A80> s/n WD-WXP1AC82RNH9 detached
Apr 14 01:14:16 freenas     (da5:mps0:0:9:0): WRITE(10). CDB: 2a 00 41 32 db 40 00 00 08 00 length 4096 SMID 834 terminated ioc 804b loginfo 31110d00 scsi 0 state c xfer 0
Apr 14 01:14:16 freenas (da5:mps0:0:9:0): CAM status: CCB request completed with an error
Apr 14 01:14:16 freenas mps0: (da5:mps0:0:9:0): Error 5, Periph was invalidated
Apr 14 01:14:16 freenas Unfreezing devq for target ID 9
Apr 14 01:14:16 freenas ZFS: vdev state changed, pool_guid=6363471716941292545 vdev_guid=17276462857189123742
Apr 14 01:14:16 freenas (da5:mps0:0:9:0): Periph destroyed
Apr 14 01:14:20 freenas mps0: SAS Address for SATA device = 456f3f37ecefbf75
Apr 14 01:14:20 freenas mps0: SAS Address from SATA device = 456f3f37ecefbf75
Apr 14 01:14:20 freenas da5 at mps0 bus 0 scbus0 target 9 lun 0
Apr 14 01:14:20 freenas da5: <ATA WDC WD20EZAZ-00G 0A80> Fixed Direct Access SPC-4 SCSI device
Apr 14 01:14:20 freenas da5: Serial Number WD-WXP1AC82RNH9
Apr 14 01:14:20 freenas da5: 600.000MB/s transfers
Apr 14 01:14:20 freenas da5: Command Queueing enabled
Apr 14 01:14:20 freenas da5: 1907729MB (3907029168 512 byte sectors)
Apr 14 01:15:10 freenas ZFS: vdev state changed, pool_guid=6363471716941292545 vdev_guid=17276462857189123742
Apr 14 01:17:09 freenas GEOM_ELI: Device mirror/swap0.eli destroyed.
Apr 14 01:17:09 freenas GEOM_MIRROR: Device swap0: provider destroyed.
Apr 14 01:17:09 freenas GEOM_MIRROR: Device swap0 destroyed.
Apr 14 01:17:09 freenas GEOM_MIRROR: Device mirror/swap0 launched (2/2).
Apr 14 01:17:09 freenas GEOM_ELI: Device mirror/swap0.eli created.
Apr 14 01:17:09 freenas GEOM_ELI: Encryption: AES-XTS 128
Apr 14 01:17:09 freenas GEOM_ELI:     Crypto: hardware
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   179   171   021    Pre-fail  Always       -       2041
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       14
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   093   093   000    Old_age   Always       -       5110
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       14
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       12
193 Load_Cycle_Count        0x0032   101   101   000    Old_age   Always       -       297616
194 Temperature_Celsius     0x0022   113   108   000    Old_age   Always       -       30
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%      5105         -
# 2  Short offline       Completed without error       00%      4868         -
# 3  Short offline       Completed without error       00%      4652         -
# 4  Extended offline    Completed without error       00%      4537         -
# 5  Short offline       Completed without error       00%      4365         -
# 6  Short offline       Completed without error       00%      4136         -
# 7  Short offline       Completed without error       00%      3968         -
# 8  Extended offline    Completed without error       00%      3859         -
# 9  Short offline       Completed without error       00%      3680         -
#10  Extended offline    Completed without error       00%      3123         -
#11  Extended offline    Completed without error       00%      2395         -
#12  Short offline       Completed without error       00%      1728         -
#13  Extended offline    Completed without error       00%      1679         -
#14  Extended offline    Completed without error       00%      1308         -
#15  Extended offline    Completed without error       00%       935         -
#16  Extended offline    Completed without error       00%       211         -
#17  Extended offline    Completed without error       00%        38         -
#18  Conveyance offline  Completed without error       00%         0         -
#19  Short offline       Completed without error       00%         0         -
HoneyBadger
actually does care
Administrator
tfran1990
So once the drive connected back the write was complete, or do i need to scrub?
The drive still has a warranty, bad thing about it is ill get another SMR disk back
