zanginator
- Jun 28, 2015
Hi for the first time,
I am hoping someone can shed some light on an issue I am having. So I have used FreeNAS now for the past year, mainly as a test for ZFS and to see if it was the right thing for me. Well I am happy to say, yes it is.
So recently I decided to bite the bullet on building a bigger machine after I acquired an old Supermicro 24 disk chassis (company upgraded and they were getting rid).
The chassis is a Supermicro SC846E1-R900B (which is a single SA8087 port 24 disk expander).
Hooked up is an LSI 9240-8i cross flashed to a 9211-8i running in IT mode. (Phase 16)
Basically, I can read from any disk no problem. However writing to the disks either stops or is VERY slow (5MB/s). On larger attempted files (larger than 100MB) the system appears to panic and reboots.
As per this thread I tried swapping the SAS cables, however this results in small files only being written and the machine shutting itself down upon any write attempt.
This also happens regardless of any disk I use. So I no reason to believe it maybe because of failing disks.
Currently I was testing under version 9.2 as I still need the UFS to migrate some older data.
Full hardware Spec:
And the output of the mps driver and card.
The only conclusion I can draw is that the SAS expander is doing something funny and is possibly failing!
If anyone has any insight or suggestions, I would be most grateful.
If you need any more info, just ask.
-zanginator
Full hardware Spec:
- Supermicro SC846E1-R900B 24 disk Chassis
- Supermicro X8DTN+
- 2x Intel Xeon L5520 (4c/8t) (8c/16t in total)
- 6x 4GB Samsung Registered ECC
- LSI 9240-8i cross-flashed to 9211-8i IT mode (phase 16)
Jul 14 14:49:36 freenas kernel: (da0:mps0:0:18:0): Retrying command (per sense data) Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a4 e7 c0 00 00 40 00 length 32768 SMID 335 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 a6 40 00 00 80 00 length 65536 SMID 334 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 c8 40 00 01 00 00 length 131072 SMID 317 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 32 c0 00 00 20 00 length 16384 SMID 316 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 32 40 00 00 80 00 length 65536 SMID 315 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 c7 40 00 01 00 00 length 131072 SMID 314 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 c6 40 00 01 00 00 length 131072 SMID 313 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 c5 40 00 01 00 00 length 131072 SMID 312 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 c4 40 00 01 00 00 length 131072 SMID 311 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 c3 40 00 01 00 00 length 131072 SMID 310 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 c2 40 00 01 00 00 length 131072 SMID 309 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 c1 40 00 01 00 00 length 131072 SMID 308 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 c0 40 00 01 00 00 length 131072 SMID 307 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 bf 40 00 01 00 00 length 131072 SMID 306 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 be 40 00 01 00 00 length 131072 SMID 305 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 bd 40 00 01 00 00 length 131072 SMID 304 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a7 bc 40 00 01 00 00 length 131072 SMID 303 terminated ioc 804b scsi 0 state c xfer 0 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): WRITE(10). CDB: 2a 00 0a a4 e7 c0 00 00 40 00 Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): CAM status: SCSI Status Error Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): SCSI status: Check Condition Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): SCSI sense: UNIT ATTENTION asc:29,0 (Power on, reset, or bus device reset occurred) Jul 14 14:49:37 freenas kernel: (da0:mps0:0:18:0): Retrying command (per sense data)
Jul 16 12:40:01 freenas kernel: mps0: <LSI SAS2008> port 0xd000-0xd0ff mem 0xfbc3c000-0xfbc3ffff,0xfbc40000-0xfbc7ffff irq 16 at device 0.0 on pci3 Jul 16 12:40:01 freenas kernel: mps0: Firmware: 16.00.00.00, Driver: 16.00.00.00-fbsd Jul 16 12:40:01 freenas kernel: mps0: IOCCapabilities: 1285c<ScsiTaskFull,DiagTrace,SnapBuf,EEDP,TransRetry,EventReplay,HostDisc>
-zanginator
