- Apr 24, 2020
Neither Disk Drill nor EaseUS supports ZFS, sorry.
www.cleverfiles.com
www.easeus.com
What Types of Drives or Disks Can I Recover Files From?
No matter what type of storage device you’ve lost data from, if you can normally connect it to your Mac and view the contents, Disk Drill can scan it. Even if you’re currently having trouble accessing your hard drive or […]
Supported file systems - EaseUS Partition Master
EaseUS Partition Master could support the following file systems: FAT12, FAT16, FAT32, NTFS and EXT2/EXT3/EXT4.
