Hard drive Failure? Help please.
eddie200112
So yesterday I received this error message near the start of a scrub.
Device: /dev/da5 [SAT], failed to read SMART Attribute Data
Device: /dev/da5 [SAT], Read SMART Error Log Failed
The volume Ravenrock (ZFS) state is DEGRADED: One or more devices could not be opened. Sufficient replicas exist for the pool to continue functioning in a degraded state.
Device: /dev/da5 [SAT], not capable of SMART self-check
Device: /dev/da5 [SAT], Read SMART Self-Test Log Failed
I then found a troubleshooting guide
https://forums.freenas.org/index.ph...leshooting-guide-basic-common-failures.41026/
But I don't have any of the tell tale positive SMART failures so I don't know whats going on. Do I replace the drive anyway?
Ill upload the smart output here as well.
smartctl 6.5 2016-05-07 r4318 [FreeBSD 10.3-RELEASE-p3 amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate NAS HDD
Device Model:     ST4000VN000-1H4168
Serial Number:    Z303A1YA
LU WWN Device Id: 5 000c50 07a985576
Firmware Version: SC46
User Capacity:    4,000,787,030,016 bytes [4.00 TB]
Rotation Rate:    5900 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Jun  3 00:59:13 2016 CDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  117) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off supp
ort.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 509) minutes.
Conveyance self-test routine
SCT capabilities:              (0x10bd) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_
FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000f   114   100   006    Pre-fail  Always       -
       67666320
  3 Spin_Up_Time            0x0003   092   091   000    Pre-fail  Always       -
       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -
       23
5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -
       0
  7 Seek_Error_Rate         0x000f   076   060   030    Pre-fail  Always       -
       45833380
  9 Power_On_Hours          0x0032   090   090   000    Old_age   Always       -
       9476
10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -
       0
12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -
       17
184 End-to-End_Error        0x0032   100   100   099    Old_age   Always       -
       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -
       0
188 Command_Timeout         0x0032   001   001   000    Old_age   Always       -
       339
189 High_Fly_Writes         0x003a   100   100   000    Old_age   Always       -
       0
190 Airflow_Temperature_Cel 0x0022   070   066   045    Old_age   Always       -
       30 (Min/Max 20/34)
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -
       0
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -
       15
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -
       23
194 Temperature_Celsius     0x0022   030   040   000    Old_age   Always       -
       30 (0 17 0 0 0)
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -
       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -
       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -
       0
SMART Error Log Version: 1
No Errors Logged
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA
_of_first_error
# 1  Extended offline    Completed without error       00%      9472         -
# 2  Short offline       Completed without error       00%      9429         -
# 3  Short offline       Completed without error       00%      9237         -
# 4  Short offline       Completed without error       00%      9045         -
# 5  Short offline       Completed without error       00%      8853         -
# 6  Extended offline    Completed without error       00%      8788         -
# 7  Short offline       Completed without error       00%      8685         -
# 8  Short offline       Completed without error       00%      8517         -
# 9  Short offline       Completed without error       00%      8325         -
#10  Short offline       Completed without error       00%      8133         -
#11  Extended offline    Completed without error       00%      8068         -
#12  Short offline       Completed without error       00%      7965         -
#13  Short offline       Completed without error       00%      7773         -
#14  Short offline       Completed without error       00%      7606         -
#15  Short offline       Completed without error       00%      7415         -
#16  Extended offline    Completed without error       00%      7327         -
#17  Short offline       Completed without error       00%      7223         -
#18  Short offline       Completed without error       00%      7103         -
#19  Short offline       Completed without error       00%      7007         -
#20  Short offline       Completed without error       00%      6911         -
#21  Short offline       Completed without error       00%      6719         -
Post the output of smartctl -x /dev/da5.
I assume the drive is attached to the LSI SAS 3008 on your motherboard, correct? What firmware version are you using?
Also, as per the forum rules, the following information would certainly help:
  • System Configuration Information: Items marked with an asterisk “*” are required for a failure postings. However, all items are recommended and could simply be part of your tag-line.
  1. * FreeNAS version (ex. “FreeNAS 9.2.1.6-Release 64-bit”)
  2. * Hardware:
  3. * Motherboard (Model)
  4. * CPU (Model)
  5. * RAM Size (in GB and model)
  6. Hard Drives (Model), Quantity, and RAIDZ configuration
  7. Add-On cards
  8. For network connectivity, include details on your network hardware/configuration.
eddie200112
Local Time is:    Fri Jun  3 14:46:54 2016 CDT
AAM feature is:   Unavailable
APM feature is:   Disabled
Rd look-ahead is: Enabled
Write cache is:   Enabled
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
                                        been run.
ort.
                                        command.
                                        power-saving mode.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate     POSR--   114   100   006    -    67666320
  3 Spin_Up_Time            PO----   092   091   000    -    0
  4 Start_Stop_Count        -O--CK   100   100   020    -    23
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  7 Seek_Error_Rate         POSR--   076   060   030    -    45833380
  9 Power_On_Hours          -O--CK   090   090   000    -    9489
10 Spin_Retry_Count        PO--C-   100   100   097    -    0
12 Power_Cycle_Count       -O--CK   100   100   020    -    17
184 End-to-End_Error        -O--CK   100   100   099    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
188 Command_Timeout         -O--CK   001   001   000    -    339
189 High_Fly_Writes         -O-RCK   100   100   000    -    0
190 Airflow_Temperature_Cel -O---K   069   066   045    -    31 (Min/Max 20/34)
191 G-Sense_Error_Rate      -O--CK   100   100   000    -    0
192 Power-Off_Retract_Count -O--CK   100   100   000    -    15
193 Load_Cycle_Count        -O--CK   100   100   000    -    23
194 Temperature_Celsius     -O---K   031   040   000    -    31 (0 17 0 0 0)
197 Current_Pending_Sector  -O--C-   100   100   000    -    0
198 Offline_Uncorrectable   ----C-   100   100   000    -    0
199 UDMA_CRC_Error_Count    -OSRCK   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x09           SL  R/W      1  Selective self-test log
0x10       GPL     R/O      1  SATA NCQ Queued Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x15       GPL     R/W      1  SATA Rebuild Assist log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa1       GPL,SL  VS      20  Device vendor specific log
0xa2       GPL     VS    4496  Device vendor specific log
0xa8       GPL,SL  VS     129  Device vendor specific log
0xa9       GPL,SL  VS       1  Device vendor specific log
0xab       GPL     VS       1  Device vendor specific log
0xb0       GPL     VS    5176  Device vendor specific log
0xbe-0xbf  GPL     VS   65535  Device vendor specific log
0xc0       GPL,SL  VS       1  Device vendor specific log
0xc1       GPL,SL  VS      10  Device vendor specific log
0xc3       GPL,SL  VS       8  Device vendor specific log
0xc4       GPL,SL  VS       5  Device vendor specific log
0xd1       GPL,SL  VS       8  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
_of_first_error
SCT Status Version:                  3
SCT Version (vendor specific):       522 (0x020a)
SCT Support Level:                   1
Device State:                        Active (0)
Current Temperature:                    31 Celsius
Power Cycle Min/Max Temperature:     21/34 Celsius
Lifetime    Min/Max Temperature:     17/49 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        94 minutes
Min/Max recommended Temperature:      1/61 Celsius
Min/Max Temperature Limit:            2/60 Celsius
Temperature History Size (Index):    128 (34)
Index    Estimated Time   Temperature Celsius
  35    2016-05-26 06:34    28  *********
  36    2016-05-26 08:08    29  **********
...    ..(  2 skipped).    ..  **********
  39    2016-05-26 12:50    29  **********
  40    2016-05-26 14:24    30  ***********
  41    2016-05-26 15:58    30  ***********
  42    2016-05-26 17:32    29  **********
  43    2016-05-26 19:06    28  *********
  44    2016-05-26 20:40    27  ********
  45    2016-05-26 22:14    29  **********
  48    2016-05-27 02:56    29  **********
  49    2016-05-27 04:30    28  *********
  50    2016-05-27 06:04    29  **********
  51    2016-05-27 07:38    29  **********
  52    2016-05-27 09:12    28  *********
53    2016-05-27 10:46    29  **********
  54    2016-05-27 12:20    30  ***********
  55    2016-05-27 13:54    30  ***********
  56    2016-05-27 15:28    29  **********
  59    2016-05-27 20:10    29  **********
  60    2016-05-27 21:44    28  *********
  61    2016-05-27 23:18    28  *********
  62    2016-05-28 00:52    29  **********
...    ..(  5 skipped).    ..  **********
  68    2016-05-28 10:16    29  **********
  69    2016-05-28 11:50    30  ***********
  70    2016-05-28 13:24    28  *********
  71    2016-05-28 14:58    29  **********
  72    2016-05-28 16:32    28  *********
  73    2016-05-28 18:06    27  ********
  74    2016-05-28 19:40    29  **********
  75    2016-05-28 21:14    28  *********
  76    2016-05-28 22:48    28  *********
  77    2016-05-29 00:22    29  **********
  78    2016-05-29 01:56    29  **********
  79    2016-05-29 03:30    30  ***********
  80    2016-05-29 05:04    30  ***********
  81    2016-05-29 06:38    29  **********
  82    2016-05-29 08:12    30  ***********
...    ..(  4 skipped).    ..  ***********
  87    2016-05-29 16:02    30  ***********
  88    2016-05-29 17:36    31  ************
  89    2016-05-29 19:10    28  *********
  90    2016-05-29 20:44    27  ********
  91    2016-05-29 22:18    28  *********
  92    2016-05-29 23:52    28  *********
  93    2016-05-30 01:26    29  **********
  99    2016-05-30 10:50    29  **********
100    2016-05-30 12:24    30  ***********
101    2016-05-30 13:58    29  **********
102    2016-05-30 15:32    28  *********
103    2016-05-30 17:06    28  *********
104    2016-05-30 18:40    29  **********
105    2016-05-30 20:14    28  *********
106    2016-05-30 21:48    29  **********
112    2016-05-31 07:12    29  **********
113    2016-05-31 08:46    30  ***********
114    2016-05-31 10:20    30  ***********
115    2016-05-31 11:54    29  **********
...    ..(  6 skipped).    ..  **********
122    2016-05-31 22:52    29  **********
123    2016-06-01 00:26    30  ***********
124    2016-06-01 02:00    30  ***********
125    2016-06-01 03:34    30  ***********
126    2016-06-01 05:08    29  **********
   3    2016-06-01 12:58    29  **********
   4    2016-06-01 14:32    28  *********
   5    2016-06-01 16:06    29  **********
   6    2016-06-01 17:40    30  ***********
   7    2016-06-01 19:14    29  **********
   8    2016-06-01 20:48    28  *********
   9    2016-06-01 22:22    28  *********
  10    2016-06-01 23:56    29  **********
  13    2016-06-02 04:38    29  **********
  14    2016-06-02 06:12    27  ********
15    2016-06-02 07:46    28  *********
  16    2016-06-02 09:20    28  *********
  17    2016-06-02 10:54    29  **********
  18    2016-06-02 12:28    29  **********
  19    2016-06-02 14:02    31  ************
  20    2016-06-02 15:36    32  *************
  21    2016-06-02 17:10    34  ***************
  22    2016-06-02 18:44    34  ***************
  23    2016-06-02 20:18    30  ***********
...    ..(  2 skipped).    ..  ***********
  26    2016-06-03 01:00    30  ***********
  27    2016-06-03 02:34    29  **********
...    ..(  3 skipped).    ..  **********
  31    2016-06-03 08:50    29  **********
  32    2016-06-03 10:24    30  ***********
  33    2016-06-03 11:58    31  ************
  34    2016-06-03 13:32    31  ************
SCT Error Recovery Control:
           Read: Disabled
          Write: Disabled
Device Statistics (GP/SMART Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x000a  2          368  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
eddie200112
I'm currently on the LSI 3008 controller firmware version 10.
BigDave
FreeNAS Enthusiast
Did you read and apply the procedure from Drive Communications Failure section?
I would cut to the chase and just replace the data cable first. The connector on the drive's
PCB could be bad, but the common failure is the data cable.
eddie200112
No I haven't checked that yet as I haven't been home yet. I will look at it tonight and try a new cable. However just had a thought , since its the SAS cable wouldn't the other drives on that cable also be having errors then? Since they all connect to the MOBO with the same connector?
No. They're independent connections, albeit bundled together for convenience. A single differential pair could be at fault, impacting only one drive.
Don't even need to ask anything else to know that that is the wrong version.
Update FreeNAS to the latest 9.10 release and update the firmware to P13 (or whatever version is now current).
eddie200112
Ya I upgraded to version 10 maybe 3 months ago but there is not a version 13 available on the supermicro site to upgrade to yet so I know I'm not running the current version. OK then it may take me a while to troubleshoot the cable as I have no spares for the SAS and Ill have to order one from Newegg as no box stores I know of in my city sell them.
To be quite honest, I get the feeling they just repackage LSI's stuff and slap supermicro filenames on that stuff, along with an admittedly neat EFI shell script that automates things.
Using LSI's firmware is probably safe. The safest option, however, is to stick with a FreeNAS version that still uses the P9 driver and flash the controller to P9. I think it was @depasseg who flashed his 3008 with LSI stock firmware...
eddie200112
OK I have a spare cable ordered. But looking inside the server I still have some terminals on the SAS cable that are not in use. Could I connect the drive to a different terminal and FreeNAS will be able to recognize it correctly?
And of course its the hardest drive to reach..
eddie200112
So I reseated the cable connection and rebooted and this is the only error message I have now. "The volume Ravenrock (ZFS) state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected." Is it fixed now?
Bidule0hm
Server Electronics Sorcerer
Yes, FreeNAS doesn't care on which port you connect the drive as long as it's connected ;)
depasseg
FreeNAS Replicant
Yes I used the LSI firmware for 9.3.1 (P9 iirc?). I haven't upgraded to 9.3.10 yet so I haven't tried the LSI p13 though.
eddie200112
OK so it went back to informing the pool is degraded. So I switched the terminal it was using on the SAS cable and booted her back up and its still gives me the error message as before "The volume Ravenrock (ZFS) state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected."
So should I send in for an RMA at this point on this drive? Was there any hints the drive is bad based on that SMART data above?
Mirfster
I only saw this (That everyone else mentioned):
  • 188 Command_Timeout -O--CK 001 001 000 - 339
Reference this: https://en.wikipedia.org/wiki/S.M.A.R.T.
The count of aborted operations due to HDD timeout. Normally this attribute value should be equal to zero and if the value is far above zero, then most likely there will be some serious problems with power supply or an oxidized data cable.
Did you get the replacement cable in yet and hook it up? How is the PSU or power cable?
joeschmuck
Old Man
My advice is to post the SMART data again from the drive and see if there are any differences between the data you first posted. And also look at all the data for all your drives for comparison, I'm curious if you have other communications issues. It would be a lot to list so you could use pastebin.com or something similar to post all the data for each drive. Also when moving a drive via the cable you need to ensure you follow the drive using the serial number of the drive.
Right now it appears you are having communication issues (as my colleagues have already speculated) but that doesn't mean it's a data cable (typically is) or it could be the controller itself, or even more rare is the hard drive electronics. I would not RMA the hard drive just yet until you can try a new data cable first.
Here are a few things you can try in the meantime:
1) Post the SMART data of all your drives so we can see if there is something obvious.
2) Relocate the drive cables around (of course power down first). I'm making an assumption here... You can swap all the drives between thier respective motherboard connections to see if the problem moves, meaning all the LSI connected drives get connected to the SATA motherboard connections. FreeNAS will not care but it's a way to see if the problem stays with the LSI connections or the hard drive.
3) Run MemTest on your system for a while to see if there are any stability issues. As mentioned above Bad Power could cause issues too.
eddie200112
So I also still have 4 open SATA ports could I just move the problem drive to a sata cable and see if that fixes the problem? Then I would know its not the SAS cable right?
Mirfster
SAS Drives cannot be connected to SATA Ports. Doesn't work. ** However SATA Drives can be connected to SAS Ports..
Just to clarify, the drive you are talking about it is a true SAS drive and not a standard SATA drive?
joeschmuck
Old Man
Yes you can. The drive model and SMART info both indicate it's a SATA drive.
