Wolfeman0101
- Jun 14, 2012
I got an email tonight saying this. Not sure what it means or how to fix it.
This email was generated by the smartd daemon running on: host name: nibbler.local DNS domain: [Unknown] NIS domain: The following warning/error was logged by the smartd daemon: Device: /dev/ada2, 1 Currently unreadable (pending) sectors For details see host's SYSLOG. You can also use the smartctl utility for further investigation. No additional email messages about this problem will be sent.
[root@nibbler] /etc# smartctl -q noserial -a /dev/ada2 smartctl 5.43 2012-06-30 r3573 [FreeBSD 8.3-RELEASE-p4 amd64] (local build) Copyright (C) 2002-12 by Bruce Allen, http://smartmontools.sourceforge.net === START OF INFORMATION SECTION === Model Family: Western Digital Caviar Green (Adv. Format) Device Model: WDC WD20EARX-00PASB0 Firmware Version: 51.0AB51 User Capacity: 2,000,398,934,016 bytes [2.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Device is: In smartctl database [for details use: -P show] ATA Version is: 8 ATA Standard is: Exact ATA specification draft version not indicated Local Time is: Sun Nov 18 21:11:34 2012 PST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x85) Offline data collection activity was aborted by an interrupting command from host. Auto Offline Data Collection: Enabled. Self-test execution status: ( 121) The previous self-test completed having the read element of the test failed. Total time to complete Offline data collection: (40860) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 394) minutes. Conveyance self-test routine recommended polling time: ( 5) minutes. SCT capabilities: (0x3035) SCT Status supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 16 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0 3 Spin_Up_Time 0x0027 175 164 021 Pre-fail Always - 6208 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 64 5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0 7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0 9 Power_On_Hours 0x0032 096 096 000 Old_age Always - 3070 10 Spin_Retry_Count 0x0032 100 253 000 Old_age Always - 0 11 Calibration_Retry_Count 0x0032 100 253 000 Old_age Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 62 192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 57 193 Load_Cycle_Count 0x0032 195 195 000 Old_age Always - 16579 194 Temperature_Celsius 0x0022 120 102 000 Old_age Always - 30 196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 1 198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Extended offline Completed: read failure 90% 3065 1159076584 # 2 Short offline Completed: read failure 90% 3064 1159076584 # 3 Short offline Completed without error 00% 3048 - # 4 Short offline Completed without error 00% 3026 - # 5 Short offline Completed without error 00% 3002 - # 6 Short offline Completed without error 00% 2978 - # 7 Short offline Completed without error 00% 2954 - # 8 Short offline Completed without error 00% 2930 - # 9 Short offline Completed without error 00% 2907 - #10 Short offline Completed without error 00% 2883 - #11 Short offline Completed without error 00% 2859 - #12 Short offline Completed without error 00% 2835 - #13 Short offline Completed without error 00% 2811 - #14 Short offline Completed without error 00% 2787 - #15 Short offline Completed without error 00% 2769 - #16 Short offline Completed without error 00% 2745 - #17 Short offline Completed without error 00% 2721 - #18 Short offline Completed without error 00% 2697 - #19 Short offline Completed without error 00% 2673 - #20 Short offline Completed without error 00% 2649 - #21 Short offline Completed without error 00% 2577 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing 3 0 0 Not_testing 4 0 0 Not_testing 5 0 0 Not_testing Selective self-test flags (0x0): After scanning selected spans, do NOT read-scan remainder of disk. If Selective self-test is pending on power-up, resume after 0 minute delay.
