Did you happen to try a different computer? If not, fire up an older computer you have stuffed in a closet somewhere. Did the trick for me.
Yes, I have tested it on my newer computer yesterday and it gave the same problem.
I've been mainly testing on my older PC that I have used in the past for wdidle3 as well as yesterday to check my older green drives/blue labeled green. My older drives can be configured in this setup.
I also found a newer version of wdidle3 v2.0.0.1, sounds like this version was given to some users with the WD Red with the LLC issue before the wd5741 tool. I ran this tool on my old 5TB blue/labeled green (mentioned above) and it was able to report my current timer setting, but will give a This drive is unsupported error on my new 6TB blue/labeled green.
I've given up on this drive, I will probably start using it and watch the LLC or use it in a offline backup.
Thanks for the advice.
