Since Supermicro does not post change notices for their BIOS and IPMI firmware upgrades, I emailed Tech Support. Here is the reply:
"Here is the change for BIOS after version 1.1:
1. Haswell Refresh supported.
2. Updated ME firmware to 3.0.5.128.
3. Updated Intel RC 1.0.0.
4. Kernel Code Update to HashWell Refresh 4.6.5.4_VEB_1ARXN004.
5. Fixed TXT test fail issue.(PBID 52311)
6. Correct BIOS setup item "Power Button Function" behavior
7. Change BIOS revision to 2.0
1. Kernel Code updated to 4.6.5.3_VEB_1AQQO021.
2. Added Intel released new microcode for Haswell CPU. {Stepping :306C3 Haswell C0,Revision:17}
3. Updated Intel RC 1.6.2.
4. Fixed SMBIOS TYPE 1 UUID can't be changed after use EEUPDATE to update onboard LAN1 EEPROM issue.
5. Fixed SUM OOB SMBIOS modification function not work properly problem.
6. Improved OOB function flow. {Funciton implement.}
7. Fixed system hanging with Xeon PHI GPU card issue.
8. Fixed system hanging with HighPoint Rocket RAID 2760&2740 storage controller card issue.
9. Fixed SERR/PERR log under SMBIOS type 15 abnormal issue.
10. Fixed there is garbage in SMBIOS type 2 version issue.
11. Fixed Location in Chassis could not change by using AMI SMBIOS utility.
12. Supported Enable/Disable Clock Spread Spectrum function for Denlow platforms with SPS ME.{Funciton implement.}
13. Patched OA3 working abnormally when flashing BIOS from IPMI and preserve NVRAM.
14. Fixed SLP2 feature not working.
15. Fixed VGA and storage card exchange no boot or device detect issue.
16. Fix Adaptec 71605 RAID card can't work issue.
17. Fixed SMBIOS data still preserve after we flash BIOS without /R command.
18. Disable the SMBIOS data write once function.{Funciton improve.}
19. Fixed [ SUM ] File is not available for download.
20. Fixed Enable/Disable the Clock Spread Spectrum option under BIOS setup menu, it can not change the Clock settings.
21. Implement the SMBIOS Type 41 information.{Funciton implement.}
22. Implement InBand SMI E7h support.{Funciton implement.}
23. Change BIOS revision to 1.1a
Here is the IPMI change after 1.23:
1. Fixed - CTLM Memory Throttling Not Working
2. Fixed - There should not be more than one IPMI console redirection allowed from IPMI webgui.
3. Fixed - Power Fail Email Alert Does Not Have Event Description to Mention Power Fail Event
4. Fixed - when updating BIOS through IPMI WEB GUI, user is still able to browse through other IPMI tabs. BIOS Update status is lost afterwards
5. Fixed - the password of AD user can't be more than 19 characters.
6. Fixed - Some SMCIPMITool Commands Not Working
7. Fixed - Active directory authentication does not work with User Domain Name
8. Fixed - firefox showed Cert error "sec_error_reused_issuer_and_serial" when using https.
9. Fixed - the bridge command through RMCP 1.5 can't work.
10. Fixed - Web GUI Console Redirection Crashed for Mac OS with Firefox and Safari Web Browser
11. Fixed - bmc cold reboot will let system reboot (Has already fixed at IPMI 1.24)
12. New feature : add VM ISO/IMA oem commands
13. Fixed - SUM 1.3.0 ] ChangeBMCcfg fail.
14. Fixed - IPMI web GUI sensor readings does not change to upper non-recoverable
15. Fixed - OEM SEL record while running IPMI on/off
16. Fixed - IPMI Firmware v1.35 has major issues
17. Fixed - 1.33 IPMI in Internet Explorer 8 has error
18. IPMI Web GUI-Some Tags don't have Japanese transaction.
19. IPMI Login page has some issues when using IE
20. Firmware v1.31 not supports "Help" Screen under BIOS Update field.
21. - FAN speed control is not working and always is Full speed
- FANA and FANB are full speed in Heavy I/O mode
- IPMI fan mode doesn't response
- Fan PWM measurement fail
- Fan PWM Test Fail
22. Fixed - CPU overheats and shuts down the system when system is in BIOS setup
23. "IP Access Control" cannot back to default setting after BMC load factory default
24. Cannot reload "Web Session", "FAN Mode" and "IP Access Control" item after reload IPMI Configuration
25. CTLM Memory Throttling Not Working
26. OOB server Asset management -DDNS
27. Fixed - The date format are different.
28. IPMI Web GUI shows incorrect IPMI Share LAN link status when the cable is unplugged.
(1)the network connectivity under all lan modes.
(2)switch lan mode,e.g. switch the failover mode to share or dedicated mode.
29. SMC RAKP
30. Add bios revision when doing bios update through web and SMCIPMItool
31. Enhance the polling time for VBAT sensor to make it more durable
32. - Add firmware recovery
- Firmware upgrade through http and https
- Firmware upgrade though dos/windows/linux utilities.
33. Support SUM to upgrade firmware.
34. The security holes about implementing the numerous unsafe string function through web interface
Please refer to the following information on CVE web site
CVE-2013-3623,CVE-2013-3622,CVE-2013-3621,CVE-2013-3623
35. The fan fail pin will be set output high at BMC initialization."
They also advised against performing any updates in the absence of any problems with the current BIOS and IPMI firmware versions.
They had no comment to make on Kingston Tech Support's response to my NewEgg review, in which they (Kingston) stated that if I wanted to add another 16GB of RAM to my system, I could move the Kingston RAM to the second pair of slots and install Hynix RAM in the first pair of slots.
- Fan PWM Test Fail
29. SMC RAKP
