I updated the BIOS and the IPMI firmware on my SuperMicro X10SL7-F to the latest versions, and now when I power it up from the Java iKVM viewer (running on Manjaro Linux) it shows "No Signal" until the boot sequence is well under way, so I have no opportunity to change any BIOS settings or even to change the IPMI UserID and Password.
UPDATE: It's the same when I use the KVM/HTML5 console redirection.
I doubt whether this is a FreeNAS problem, but I'll report it here in case someone else has encountered the same problem.
Another UPDATE: I did manage to get into the BIOS by pressing <DEL> on the virtual keyboard repeatedly even when "No Signal" was still showing. And I realized that the IPMI User ID and Password are changed from the IPMI screen, not from the BIOS.
