FS: FreeNAS Mini with optional HDD
Slovak
For sale is a 4-bay FreeNAS Mini with optional HDD configuration (read below)
Bare system (with upgraded RAM): $700 (30% off new price)
4x 3TB HDD (3/4 in warranty): $350 ($50 off with system, total $1,000)
4x 5TB HDD (all 4 in warranty): $650 ($50 off with system, total $1,300)
System plus all 8 disks: $100 discount, total of $1,600
Shipping (FreeNAS Mini bare or with HDDs): $50
Specs:
  • Small Form factor with 4 Hot-Swap SATA drive bays
  • Dimensions: 8.40" W x 11.0"D x 9.45" H (213 x 280 x 240mm)
  • Weight:– 10.8lb (without drives)
  • 32GB ECC Memory (upgraded from stock)
  • Intel Avoton C2750D4I 8-Core 2.4GHz Processor supports Fast Encryption
  • SATA DOM (16GB) boot device
  • 2x On-board Gigabit network controllers
  • 1x Dedicated IPMI port
  • 3x USB ports
  • Slots: 1x PCI-Express 2.0 x8 Slot
  • SATA: 8x SATA3 Ports, 4x SATA2 Ports
  • Super quiet and energy efficient design
Formal specs and pretty pictures: https://www.ixsystems.com/freenas-mini/
I purchased this system brand new from iXsystems in 2015. The system runs ZFS, and is as close to silent as possible. It is whisper quiet, and is a strong performer. It far outpaces the prepackaged systems like Qnap/Synology, especially when you start adding packages like Plex transcoding, CrashPlan, or other utilities. I have installed a fresh copy of Freenas 11, and I would be happy to preconfigure the IPMI and FreeNAS network settings for the buyer, for a painless setup.
I have had the system powered off for the last 8 months since consolidating on to my larger FreeNAS system. I am located in Dallas, Texas and there is no charge for local pickup.
Seller is an eBay member since 1999: p271 with 29 reviews and Positive Feedback (last 12 months): 100%
PayPal available for payment. I can post this on eBay (and pay the fees) if that helps with buyer protection.
You can also message me through my profile.
joeschmuck
Old Man
I would recommend that you also post this on ebay. If you use PayPal then you should also update your first posting to include that too. Here on these forums we like to use other services for sales in order to protect both the buyer and seller, especially when it comes to high cost items.
With respect to the hard drives, I would recommend that you post the smartctl -x /dev/adax output for all your hard drives. This would tell us the make/model, serial number so we can see what the warranty expiration date actually is, and check out any errors. If you haven't done a SMART Long/Extended test in a while then I'd ensure you do that first so that data is present. I only say this because this is the data I would desire if I were to buy a used hard drive.
Good luck with your sale.
Slovak
Thanks for the suggestions. I edited the first message to add PayPal info / eBay posting in case someone would prefer to go through that channel.
Have run SMART reports on schedule, just forgot to include them. Attached.
To verify warranty status, go to https://support.wdc.com/warranty/warrantystatus.aspx
List of all 8 serial numbers for convenience: WCC4N7XV1HEH, WCC4N3JER5NP, WCC4N1NL0NNS, WCC4N2YPJDR0, WX21D45C7LUX, WX21D25HEEXV, WX71D65JEA36, WX91D6535EN0
3TB
WCC4N7XV1HEH: Out of warranty
WCC4N3JER5NP: 1/10/2018 (listed as "out of region", but in my WD Support portal it lists the warranty)
WCC4N1NL0NNS: 1/1/2018 (listed as "out of region", but in my WD Support portal it lists the warranty)
WCC4N2YPJDR0: 2/13/2018
5TB
WX21D45C7LUX: 5/12/2019
WX21D25HEEXV: 5/12/2019
WX71D65JEA36: 5/12/2019
WX91D6535EN0: 5/12/2019
  • 3TB.txt
  • 5TB.txt
