Abdullah123
- Aug 6, 2018
Hi there,
I have been using FreeNAS since version 9. I recently updated to version 11 and absolutely loving it. The only problem is that this time around I had set up my email so it sends me notifications if there's any problem with the server.
I am getting below notification like at least 10 to 12 times a day and would like to know is this something that I should be worried about?
Also, I saw some scripts floating around to create a backup of FreeNAS 11.2 configuration. I am not sure which one easier to work with but if there's a simplified version a script which will send me an email as well with the configuration file once it's done would be awesome. Is it better to move FreeNAS to an SSD or some sort of internal storage? Or running off of USB stick is fine?
Thanks a lot!
NTP status: No response received from xx.xxx.xxx.x.
NTP status: 1 out of 8 probes failed
Thanks a lot!
