NTP health check failed - No Active NTP peers
unixland
I am running TrueNAS Scale on a Dell T620 and I am getting the following notifications from the system frequently:
NTP health check failed - No Active NTP peers: [{'192.168.178.44': 'REJECT'}]
The notice does go away after a while but comes up again at random times.
Since the NTP server is in the local network with no firewalling whatsoever, and all my other devices do not have this problem connecting to the NTP server, I do suspect the problem lies somewhere within TrueNAS SCALE.
How to troubleshoot this issue ?
Best regards,
Rick
Dell T620 with Dual Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz, 256 GB ECC RAM, Intel Corporation Ethernet Controller 10G X550T, running on TrueNAS SCALE TrueNAS-SCALE-22.12.1
unixland
*bump*
Make sure CMOS time is set to UTC time, not local time.
unixland
Thank you for your reply. Just wondering here what influence the CMOS time has to NTP.
Upon boot up the system time is initialized to the CMOS clock. If CMOS clock is set to local time, when the NTP daemon tries to sync with a NTP server, when the time offset is greater than 1000 seconds, it will not sync with the NTP server.
unixland
ah, ok, well, this is not the case. And, as I mentioned earlier, this happens on and off, so it does sync, just not always.
