- May 19, 2017
I'd go with a Centerclick NTP200 or NTP250 solution instead. Custom-built, super simple to set up, and unlike a RPi+Uputronics or like hat, the thing has a TCXO for the times that Baidu, GLONASS, Galileo, and GPS are not available.Would this work? https://austinsnerdythings.com/2021/04/19/microsecond-accurate-ntp-with-a-raspberry-pi-and-pps-gps/ I'm not obsessed with dirt cheap - an under $100. solution seems reasonable.
I also have a Pi with the uputronics hat and found the NTP200 to be a much better solution since it's tailored to be a accurate time server first and foremost.
For me, the NTP200 is a much better value as long as you don't consider your time to be free. Plus, it already has a case, power supply, and antenna included. I also find the web-based, detailed status-screens on the NTP200 to be far more usable than the crude stuff the RPi can show.
