did you have linprocfs mounted? The plugin does this when you stop and start it from the FreeNAS WebUI > Plugins > Installed tab.Oddly enough, I just installed a fresh copy of the latest MineOS node version in a brand new jail (not using the plugin) and got the same error, so something weird is going on with my system. I'm just not sure what.
good to knowYes I do, and sorry, I'm posting in too many threads. This was caused by a bug in the current MineOS-node git repo, so I highly recommend that no one update right now, or your MineOS will crash and burn too. See here for more info:
https://discourse.codeemo.com/t/fresh-mineos-install-on-freenas-jail-fails-to-start/1926
Did you check the logs for that server? On the first run you may need to accept the EULA.Hi. When I hit start after creating a server nothing happens. Any ideas?
Have you tried updating node/MineOS?Hi. The EULA is set to true. If i look in the mineos log it shows this when I hit "start", but nothing after,
"{"level":"info","message":"[ChrisCraft] received request \"start\"","timestamp":"2017-06-27T14:18:06.826Z"}"
root@mineos_1:/ # service mineos onestop
Stopping mineos.
Waiting for PIDS: 38327, 38327.
root@mineos_1:/ # service mineos oneupdate
Already up-to-date.
Did you ever run these commands? That would update your node version.Yes it says it is up to date. I'm not sure what you mean by node though?
Stopping mineos.
Already up-to-date.
pkg install -y npm sed -i '' -e 's|^\(command="\).*\("\)$|\1/usr/local/bin/node\2|' /usr/local/etc/rc.d/mineos sed -i '' -e 's|^\(start_precmd="\).*\("\)$|\1export PATH=$PATH:/usr/local/bin:/usr/pbi/mineos-amd64/bin\2|' /usr/local/etc/rc.d/mineos sed -i '' -e 's|^\([[:space:]]*\)/.*/npm\([[:space:]].*\)$|\1CXX=c++ /usr/local/bin/npm\2|' /usr/local/etc/rc.d/mineos
root@mineos_1:/ # pkg install -y npm Updating FreeBSD repository catalogue... [mineos_1] Fetching meta.txz: 100% 940 B 0.9kB/s 00:01 [mineos_1] Fetching packagesite.txz: 100% 6 MiB 6.1MB/s 00:01 Processing entries: 100% FreeBSD repository update completed. 26608 packages processed. All repositories are up to date. Checking integrity... done (0 conflicting) The most recent version of packages are already installed root@mineos_1:/ # sed -i '' -e 's|^\(command="\).*\("\)$|\1/usr/local/bin/node\2 |' /usr/local/etc/rc.d/mineos root@mineos_1:/ # sed -i '' -e 's|^\(start_precmd="\).*\("\)$|\1export PATH=$PAT H:/usr/local/bin:/usr/pbi/mineos-amd64/bin\2|' /usr/local/etc/rc.d/mineos root@mineos_1:/ # sed -i '' -e 's|^\([[:space:]]*\)/.*/npm\([[:space:]].*\)$|\1C XX=c++ /usr/local/bin/npm\2|' /usr/local/etc/rc.d/mineos root@mineos_1:/ #
Hmm, can you confirm linprocfs is loaded?Hi. Ye I have run those ones too.
Code:root@mineos_1:/ # pkg install -y npm Updating FreeBSD repository catalogue... [mineos_1] Fetching meta.txz: 100% 940 B 0.9kB/s 00:01 [mineos_1] Fetching packagesite.txz: 100% 6 MiB 6.1MB/s 00:01 Processing entries: 100% FreeBSD repository update completed. 26608 packages processed. All repositories are up to date. Checking integrity... done (0 conflicting) The most recent version of packages are already installed root@mineos_1:/ # sed -i '' -e 's|^\(command="\).*\("\)$|\1/usr/local/bin/node\2 |' /usr/local/etc/rc.d/mineos root@mineos_1:/ # sed -i '' -e 's|^\(start_precmd="\).*\("\)$|\1export PATH=$PAT H:/usr/local/bin:/usr/pbi/mineos-amd64/bin\2|' /usr/local/etc/rc.d/mineos root@mineos_1:/ # sed -i '' -e 's|^\([[:space:]]*\)/.*/npm\([[:space:]].*\)$|\1C XX=c++ /usr/local/bin/npm\2|' /usr/local/etc/rc.d/mineos root@mineos_1:/ #
[root@Server ~]# mount | grep linprocfs
linprocfs on /mnt/Jails/mineos_1/usr/compat/linux/proc (linprocfs, local)
[root@Server ~]#
linprocfs is not dependent on those CPU features.
[root@Server ~]#
Could it be my system isn't able to run it? It cant run the new 11 VM stuff. When I connect with VNC the server stops, sometimes crashing the FreeNAS web GUI with it.
Another thing I thought off. Do later versions of minecraft need java8?OK thanks for your time.
awesome. man that would be nice if I could update this plugin to include the latest node and java so this just all worked.Progress. Thanks man. Seems running that Java command is all what was needed.
