Natalie Cooper
- Mar 25, 2017
So I just looked up the serial number and this is what it came back with
HP Micro G7 N36L NHP 250GB EU
I don't think you'll need it, the procedure applies only AFTER you got freenas installed.but I may need some help with the gparted.
FreeNas 8 is really old, try not to go there.
What I would do if I were you:
1. breathe! ;)
2. quickly try to boot https://download.freenas.org/9.10/RELEASE/x64/FreeNAS-9.10-RELEASE.iso
3. make sure the machine is up2date in terms of bios/firmware/... Now you have entered the serial at HP, you should be able to see and download the latest versions.
4. retry
5. if all of the above fails, is there a cd/dvd present in the microserver? Can you boot from there?
Not yet. How does a stick with 9.10-RELEASE on it behaves in the system?I have a USB CD drive, so could try that if you can suggest something
Not yet. How does a stick with 9.10-RELEASE on it behaves in the system?[/QUOTE]QUOTE="Natalie Cooper, post: 363013, member: 72638"]I have a USB CD drive, so could try that if you can suggest something
Breathing :)
Ok so I cant download the BIOS without paying for a warranty, so thats a no go.
1. breathe! ;)
4. retry
But it worked before!Its simply not going to work. :( Guess I will just have to not use FreeNAS.
But it worked before!![]()
yes it did.. Which is why I am so frustrated. See my post above.. the only thing I can think of is the graphics adapter.. I am sure last time i did it I just used a standard VGA screen which I no longer have and using the TV now. But this server only has VGA so I am using a converter from VGA to HDMI and I wonder if something is up with that
You say you can boot the server into other operating systems, Is that with the hardware configuration (using the TV and VGA/HDMI convertor) you have now in place, so that it's only your FreeNAS stick that will not boot "to completion"?
If you boot into Ubuntu and press alt-shift-(some f-key), does it comes back with a text-mode login prompt? Maybe idd only a graphical GUI is displayed correctly on your TV set.
Just to be sure, you booted Ubuntu in graphical mode, not in text mode?
