FreeNAS 11U4 shows up as 11U2 in my system
NasKar
I installed an SSD as my boot drive and changed the BIOS setting to get it to boot from it instead of my USB stick. After a fresh install of FN11U4 on my SSD I rebooted and the system info says I have FN11U2. The USB stick had U3 on it. Thinking I made an error in my download I recreated the USB install of U4 after a fresh download of it. After my reinstall and reboot again it says U2. I upgrade the U2 to U4 from the GUI and rebooted and again it says i'm using FN11U2. I'm completely confused. Any idea on what's happening?
One of two things, it's either not completing (USB sticks take a LONG time so start the update and leave it alone for a few hours), or it's not switching like it should in which case click on the system tab and the boot sub-tab and make sure the environment says "On Reboot" for the version you are wanting to use, then reboot and it should be the right one. Every once in a while it will act up.
NasKar
After rebooting and selecting the SSD ada0 from the boot menu it still boots from the USB stick da0. Do I have to remove the USB from the motherboard to boot from the SSD?
NasKar
It seems like the system booted from the USB drive anyway and used the original install of U2. I removed the USB stick and it booted from the SSD on an
IO Crest SI-PEX40062 4 Port SATA III PCIe 2.0 x2 Controller Card. After uploading the config to the clean install of FN11U4 I noticed errors before it gets to the actual FreeNAS boot menu I think they were HDD errors. Scrolled to fast to get a screen capture of it. Checking the desmsg.today file I found 2 errors.
pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
pcib0: _OSC returned error 0x10
pci0: <ACPI PCI bus> on pcib0
pcib1: <ACPI PCI-PCI bridge> irq 16 at device 1.0 on pci0
pci1: <ACPI PCI bus> on pcib1
and
WARNING: VIMAGE (virtualized network stack) is a highly experimental feature.
ioapic0 <Version 2.0> irqs 0-23 on motherboard
random: entropy device external interface
kbd1 at kbdmux0
module_register_init: MOD_LOAD (vesa, 0xffffffff80fa9d40, 0) error 19
random: registering fast source Intel Secure Key RNG
random: fast provider: "Intel Secure Key RNG"
nexus0
cryptosoft0: <software crypto> on motherboard
