TechnoPallidin
- Dec 2, 2023
So, it's time to upgrade. I have been running with one of the synology desktop 4 bay nas for the last couple of years and my disk space needs have started to explode. Dang video editing...
As with all things I have been upgrading my entire home network and I'm now moving into a rack based solution. My closet has enough space (and airflow) to support a 22U rack but it's a 24x24" cube style 22U tall. It's the best I can get that also carries the WAF (wife approval factor). Although I'm already expecting complaints. :)
This rack, link below, has a max depth of 21" as per there spec. so I'm trying to target between 17-19" depth chassis. I had thought about just using a qnap off the shelf product but thought, lets build my own. Since I need lots of storage. My starting Target is to try and get between an 8-12 disk setup that I want to run at a Raid 5/6 equivalent. I'm not really planning to use any VM/Containers on this box as I also plan to build a dedicated proxmox server to run plex and serve videos from this nas. At least that is my plan...
Enter the build delima and trying to find something that works. :)
I would "love" to have hot swap drive racks but if it's just not feasible then so be it. 2U/3U/4U all good. I'm also thinking to see if I can also add some sort of JBOD to allow for temp/work storage with final products going to the raid array. Think, Rip Blu-Ray to JBOD, convert (handbrake on proxmox) to the Raid array. Then I can just delete the dump. Simple example... On the flip side, would I run maybe 2 different TrueNas metal based instances? one for the Raid server using all drives, and another for a JBOD server with it's own drives? no clue, kinda new on that one.
I have been hunting and I think I found some things that "Might" work, however I thought to ask the community in case there is something better out there.
This case is right at 19", not sure how good it is or what I need to put in it yet... I figure I need to start somewhere. The case being the biggest limiting factor.
2U Chassis: SilverStone RM21-308 (8 drive unit, would prefer 12 or more even if bigger form factor)
This is my Rack: SysRack 22U
I have looked at some of the SuperMicro but everything I seem to find is almost 26" deep.
Any thoughts on this? Recommendations? I have been looking through posts but a lot are really old and dead links with searches returning nothing.
My end goal is 8-12 in some RAID config... then I would love to have another 8 or so in a JBOD for just "use" as it were. whether that means 2-3 cases or whatever is also part of what I'm trying to figure out. I wish the size limitation wasn't present, it is what it is though.
Thanks.
Thanks.
