PhilD13
- Sep 18, 2020
Anyone know if the Supermicro AS -2014S-TR server will work out of the box with TrueNAS Scale without requiring any additional cards (LSI IT mode cards etc.} or hoops to jump through?
I am going to be replacing a old 36TB QNAP rack server that has become unreliable hardware wise. I am thinking of using a
Supermicro A+ SuperServer model: AS -2014S-TR in basically a default configuration setup from Supermicro.
Single 7302 Processor 16-Core 3.00GHz 128MB Cache
64GB DDR4 3200MHz ECC RDIMM Server Memory - (increased from 16GB)
using the rear 2 slots for boot disk in a mirror config. - (deleted single front drive added 2 ssd's to rear slots)
Populated with 8 SATA drives I already have to start with
The primary usage is for file and photo storage for windows computers.
It will also have an old Supermicro SC836 16 bay JBOD chassis connected to it and populated with 8 SATA drives I have to start with. The JBOD will be connected with an LSI type pci IT mode card
I did see one person on the forum that was using or planning to use this server with TrueNas scale but it was not in much detail of the setup.
