I am new to the forums but I have enjoyed reading through the numerous amounts of documentation available and various threads about new builds. I believe I now have a clearer understanding of what hardware might work for this purpose and I would be grateful for any feedback on what I am considering for a build of a TrueNAS Scale system for video editing (1-2 users). This server will also need to run Plex and I would like to install Roon (audio server software) as well.
Here is what I am considering:
Are there any thoughts on whether I will need to add another pool of SSDs for current video projects in addition to the spinning drives or do you think I will have fast enough read access with 6 drives in a ZFS2 configuration?
I am grateful for any feedback that you might be able to provide. Thank you in advance.
Description | Notes | |
CPU | Epyc 7302P | |
Mobo | ASRock Rack ATX ROMED8-2T | Dual 10G RJ45 Intel -- supports 8 SATA on board (6 20TB + 1 boot drive) + 1 M.2 slot for NVMe |
RAM | Micron RDIMM DDR4-3200 ECC 32GB 2Rx4 | 128GB total |
Case | Fractal Design Define 7 XL | |
HDD | WD RED PRO 20TB | 6 in total in ZFS2 configuration |
L2Arc NVMe | Sabrent 1TB Rocket 4 Plus NVMe | per 1GB ram, 5GB for L2Arc |
CPU Cooler | Noctua NH-U14S | |
Boot Drive SSD | Samsung 870 EVO 500GB SATA | dual boot drives? |
Power Supply | Seasonic Prime Titanium 1000W TX-1000 | 14x SATA power connectors, 80+ Titanium rating |
Case Fans | Fractal X2 GP-14 140mm | 3 fans already included, add 2 more? |
GPU (for Plex Transcoding) | NVIDIA Quadro P1000? | https://www.elpamsoft.com/?p=Plex-Hardware-Transcoding (75W, 3 HEVC/h.264 streams) |
