Hi All:
I've been stabilizing my second Freenas server after a few DOA hardware pieces that were difficult to diagnose. One of the items I am trying to get working is fan control. My motherboard is a X10SRL-F in a 4u SuperMicro Chassis. The fans are set up per the scripts (FANA feeds the 3 mid-chassis fans and FAN1, 3, & 4 feed fans on the CPU heatsink and the rear case fans). I have reviewed all the documentation, set the upper and lower thresholds, and am now realizing that regardless of scripts, it seems like the duty cycle is not being set. I say this after trying the raw set/read commands myself and running the spintest script - you can see the output below. Any ideas on why this isn't working? I've tried searching in case there was an obvious config change that I needed to make but can't find it.
Thanks again for all your help.
-A
And in case it is helpful, sensor list is:
-A
Saturday, Apr 07, 17:19:15 ___Duty%___ Curr_RPM____________________ MODE Zone0 Zone1 FANA FAN1 FAN2 FAN3 FAN4 Conditions before test Full 100 100 4800 1600 --- 6100 6000 Are you ready to begin? (y/n) y Saturday, Apr 07, 17:19:19 ___Duty%___ Curr_RPM____________________ MODE Zone0 Zone1 FANA FAN1 FAN2 FAN3 FAN4 Duty cycle 100% Full 100 100 4800 1600 --- 6100 6000 Duty cycle 90% Full 100 100 4800 1600 --- 6100 6000 Duty cycle 80% Full 100 100 4800 1600 --- 6100 6000 Duty cycle 70% Full 100 100 4800 1600 --- 6100 6000 Duty cycle 60% Full 100 100 4800 1600 --- 6100 6000 Duty cycle 50% Full 100 100 4800 1600 --- 6100 6000 Duty cycle 40% Full 100 100 4800 1600 --- 6100 6000 Duty cycle 30% Full 100 100 4800 1600 --- 6100 6000 Duty cycle 20% Full 100 100 4800 1600 --- 6100 6000
CPU Temp | 26.000 | degrees C | ok | 0.000 | 0.000 | 0.000 | 91.000 | 96.000 | 96.000 PCH Temp | 29.000 | degrees C | ok | 0.000 | 5.000 | 16.000 | 90.000 | 95.000 | 100.000 System Temp | 18.000 | degrees C | ok | -10.000 | -5.000 | 0.000 | 80.000 | 85.000 | 90.000 Peripheral Temp | 22.000 | degrees C | ok | -10.000 | -5.000 | 0.000 | 80.000 | 85.000 | 90.000 VcpuVRM Temp | 28.000 | degrees C | ok | -5.000 | 0.000 | 5.000 | 95.000 | 100.000 | 105.000 VmemABVRM Temp | 28.000 | degrees C | ok | -5.000 | 0.000 | 5.000 | 95.000 | 100.000 | 105.000 VmemCDVRM Temp | 23.000 | degrees C | ok | -5.000 | 0.000 | 5.000 | 95.000 | 100.000 | 105.000 DIMMA1 Temp | 21.000 | degrees C | ok | -5.000 | 0.000 | 5.000 | 80.000 | 85.000 | 90.000 DIMMA2 Temp | na | | na | na | na | na | na | na | na DIMMB1 Temp | 20.000 | degrees C | ok | -5.000 | 0.000 | 5.000 | 80.000 | 85.000 | 90.000 DIMMB2 Temp | na | | na | na | na | na | na | na | na DIMMC1 Temp | na | | na | na | na | na | na | na | na DIMMC2 Temp | na | | na | na | na | na | na | na | na DIMMD1 Temp | na | | na | na | na | na | na | na | na DIMMD2 Temp | na | | na | na | na | na | na | na | na FAN1 | 1600.000 | RPM | ok | 300.000 | 400.000 | 500.000 | 1700.000 | 1800.000 | 2000.000 FAN2 | na | | na | na | na | na | na | na | na FAN3 | 6100.000 | RPM | nr | 500.000 | 600.000 | 700.000 | 5600.000 | 5800.000 | 6000.000 FAN4 | 6000.000 | RPM | nr | 500.000 | 600.000 | 700.000 | 5600.000 | 5800.000 | 6000.000 FAN5 | na | | na | na | na | na | na | na | na FANA | 4800.000 | RPM | ok | 300.000 | 400.000 | 500.000 | 5600.000 | 5800.000 | 6000.000 12V | 12.000 | Volts | ok | 10.173 | 10.299 | 10.740 | 12.945 | 13.260 | 13.386 5VCC | 5.026 | Volts | ok | 4.246 | 4.298 | 4.480 | 5.390 | 5.546 | 5.598 3.3VCC | 3.350 | Volts | ok | 2.789 | 2.823 | 2.959 | 3.554 | 3.656 | 3.690 VBAT | 3.047 | Volts | ok | 2.375 | 2.487 | 2.599 | 3.775 | 3.887 | 3.999 Vcpu | 1.809 | Volts | ok | 1.242 | 1.260 | 1.395 | 1.899 | 2.088 | 2.106 VDIMMAB | 1.200 | Volts | ok | 0.948 | 0.975 | 1.047 | 1.344 | 1.425 | 1.443 VDIMMCD | 1.191 | Volts | ok | 0.948 | 0.975 | 1.047 | 1.344 | 1.425 | 1.443 5VSB | 4.948 | Volts | ok | 4.246 | 4.298 | 4.480 | 5.390 | 5.546 | 5.598 3.3VSB | 3.316 | Volts | ok | 2.789 | 2.823 | 2.959 | 3.554 | 3.656 | 3.690 1.5V PCH | 1.518 | Volts | ok | 1.320 | 1.347 | 1.401 | 1.644 | 1.671 | 1.698 1.2V BMC | 1.218 | Volts | ok | 1.020 | 1.047 | 1.092 | 1.344 | 1.371 | 1.398 1.05V PCH | 1.050 | Volts | ok | 0.870 | 0.897 | 0.942 | 1.194 | 1.221 | 1.248 Chassis Intru | 0x1 | discrete | 0x0100| na | na | na | na | na | na PS1 Status | 0x1 | discrete | 0x0100| na | na | na | na | na | na PS2 Status | 0x1 | discrete | 0x0100| na | na | na | na | na | na
