On the reported disk I ran a SMART test which lasted hours.
Now I have detected the SMART status of all 3 disks.
I'm surprised by the Prefail reports.
The disks were purchased years ago, but used very little, both in terms of hours of work, but also in terms of load.
However for all three disks I see similar results and the final result is "No errors".
So why does the sde2 disk slow down the NAS by keeping the CPU at 100%?
Test on SDC
root@gp-hq-bck-srv[/home/admin]# smartctl /dev/sdc -a
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.79+truenas] (local build)
Model Family: Western Digital Red
Device Model: WDC WD30EFRX-68AX9N0
Serial Number: WD-WMC1T3959004
LU WWN Device Id: 5 0014ee 2b3a3ad75
Firmware Version: 80.00A80
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Sep 13 08:47:45 2023 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x02) Offline data collection activity
was completed without error.
been run.
data collection: (41040) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 412) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x70bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x002f 200 200 051 Pre-fail Always - 0
3 Spin_Up_Time 0x0027 177 175 021 Pre-fail Always - 6125
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 232
5 Reallocated_Sector_Ct 0x0033 200 200 140 Pre-fail Always - 0
7 Seek_Error_Rate 0x002e 200 200 000 Old_age Always - 0
9 Power_On_Hours 0x0032 089 089 000 Old_age Always - 8400
10 Spin_Retry_Count 0x0032 100 100 000 Old_age Always - 0
11 Calibration_Retry_Count 0x0032 100 100 000 Old_age Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 232
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 85
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 146
194 Temperature_Celsius 0x0022 111 107 000 Old_age Always - 39
196 Reallocated_Event_Count 0x0032 200 200 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 200 200 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 200 200 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
200 Multi_Zone_Error_Rate 0x0008 200 200 000 Old_age Offline - 0
SMART Error Log Version: 1
No Errors Logged
# 1 Short offline Completed without error 00% 8377 -
# 2 Extended offline Completed without error 00% 336 -
# 3 Short offline Completed without error 00% 328 -
# 4 Short offline Completed without error 00% 326 -
# 5 Short offline Completed without error 00% 326 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Test on SDD
root@gp-hq-bck-srv[/home/admin]# smartctl /dev/sdd -a
Serial Number: WD-WMC1T4142913
LU WWN Device Id: 5 0014ee 25e4df2eb
Local Time is: Wed Sep 13 08:48:56 2023 CEST
was never started.
been run.
data collection: (40080) seconds.
command.
power-saving mode.
recommended polling time: ( 402) minutes.
3 Spin_Up_Time 0x0027 177 175 021 Pre-fail Always - 6133
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 234
9 Power_On_Hours 0x0032 089 089 000 Old_age Always - 8401
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 234
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 88
193 Load_Cycle_Count 0x0032 200 200 000 Old_age Always - 145
194 Temperature_Celsius 0x0022 110 107 000 Old_age Always - 40
198 Offline_Uncorrectable 0x0030 100 253 000 Old_age Offline - 0
No Errors Logged
# 1 Extended offline Completed without error 00% 336 -
# 2 Short offline Completed without error 00% 328 -
# 3 Short offline Completed without error 00% 326 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Test on SDE (Disk with error messages)
root@gp-hq-bck-srv[/home/admin]# smartctl /dev/sde -a
Serial Number: WD-WMC1T3958590
LU WWN Device Id: 5 0014ee 2b3a3d36b
Local Time is: Wed Sep 13 08:44:55 2023 CEST
was never started.
been run.
data collection: (40860) seconds.
command.
power-saving mode.
recommended polling time: ( 410) minutes.
3 Spin_Up_Time 0x0027 179 177 021 Pre-fail Always - 6033
192 Power-Off_Retract_Count 0x0032 200 200 000 Old_age Always - 86
194 Temperature_Celsius 0x0022 109 105 000 Old_age Always - 41
No Errors Logged
# 1 Extended offline Completed without error 00% 8394 -
# 2 Extended offline Completed without error 00% 335 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
