Spud
- Oct 23, 2011
Heres what I would like to get working but I'm a little stuck on where to look next
I have 2 freenas boxes, mines local with a static IP lets call that one (A) and the other will be at a remote location with a dynamic IP lets call that one (B).
So obviously the remote system (B) needs to be the one making the connection and doing the downloading seeing it has a dynamic IP address.
I've setup rsync modules between the 2 and it works fine with both systems on the same local network but I can see a problem when (B) is moved remotely.
Making the connection from (A) to (B) and sending the files seems easy enough and I have that working no problems, but I can't work out how to make system (B) make the connection and pull the files from (A)
I'm sure it can be done but I'm stuffed if I can work out how to do it, so any help here would be very much appreciated.
Thanks in advance
Thanks in advance
