willtruenas111
- Aug 16, 2022
Hi
I got this critical error on my TrueNAS:
* Pool RAID state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
* Device: /dev/ada3, ATA error count increased from 0 to 12.
Does anyone have any insight as to what I should do about this or what significance it has?
I ran smartctl -a /dev/ada3 and this is the output:
I also ran the same command on a disk that didn't have any errors: smartctl -a /dev/ada3:
root@truenas[~]# smartctl -a /dev/ada3 smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Barracuda 7200.11 Device Model: ST31000333AS Serial Number: 6TE08VNS LU WWN Device Id: 5 000c50 00e3c550f Firmware Version: SD35 User Capacity: 1,000,204,886,016 bytes [1.00 TB] Sector Size: 512 bytes logical/physical Rotation Rate: 7200 rpm Device is: In smartctl database [for details use: -P show] ATA Version is: ATA8-ACS T13/1699-D revision 4 SATA Version is: SATA 2.6, 3.0 Gb/s Local Time is: Tue Aug 16 09:58:18 2022 BST ==> WARNING: There are known problems with these drives, see the following Seagate web pages: http://knowledge.seagate.com/articles/en_US/FAQ/207931en http://knowledge.seagate.com/articles/en_US/FAQ/207951en http://knowledge.seagate.com/articles/en_US/FAQ/207957en SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED See vendor-specific Attribute list for marginal Attributes. General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 617) seconds. Offline data collection capabilities: (0x7b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 1) minutes. Extended self-test routine recommended polling time: ( 212) minutes. Conveyance self-test routine recommended polling time: ( 2) minutes. SCT capabilities: (0x103b) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 10 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x000f 099 099 006 Pre-fail Always - 28959177 3 Spin_Up_Time 0x0003 093 091 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 097 097 020 Old_age Always - 3587 5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 40 7 Seek_Error_Rate 0x000f 072 060 030 Pre-fail Always - 20467954 9 Power_On_Hours 0x0032 019 019 000 Old_age Always - 71259 10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 34 12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 205 184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0 187 Reported_Uncorrect 0x0032 088 088 000 Old_age Always - 12 188 Command_Timeout 0x0032 100 087 000 Old_age Always - 124556607584 189 High_Fly_Writes 0x003a 001 001 000 Old_age Always - 292 190 Airflow_Temperature_Cel 0x0022 059 033 045 Old_age Always In_the_past 41 (Min/Max 38/42 #1079) 194 Temperature_Celsius 0x0022 041 067 000 Old_age Always - 41 (0 16 0 0 0) 195 Hardware_ECC_Recovered 0x001a 046 024 000 Old_age Always - 28959177 197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 ATA Error Count: 12 (device log contains only the most recent five errors) CR = Command Register [HEX] FR = Features Register [HEX] SC = Sector Count Register [HEX] SN = Sector Number Register [HEX] CL = Cylinder Low Register [HEX] CH = Cylinder High Register [HEX] DH = Device/Head Register [HEX] DC = Device Command Register [HEX] ER = Error register [HEX] ST = Status register [HEX] Powered_Up_Time is measured from power on, and printed as DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes, SS=sec, and sss=millisec. It "wraps" after 49.710 days. Error 12 occurred at disk power-on lifetime: 5717 hours (238 days + 5 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: WP at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 61 00 10 ff ff ff 4f 00 26d+05:48:32.532 WRITE FPDMA QUEUED 60 00 08 ff ff ff 4f 00 26d+05:48:32.532 READ FPDMA QUEUED 2f 00 01 10 00 00 00 00 26d+05:48:32.452 READ LOG EXT 61 00 10 ff ff ff 4f 00 26d+05:48:29.346 WRITE FPDMA QUEUED 60 00 08 ff ff ff 4f 00 26d+05:48:29.346 READ FPDMA QUEUED Error 11 occurred at disk power-on lifetime: 5717 hours (238 days + 5 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: WP at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 61 00 10 ff ff ff 4f 00 26d+05:48:29.346 WRITE FPDMA QUEUED 60 00 08 ff ff ff 4f 00 26d+05:48:29.346 READ FPDMA QUEUED 2f 00 01 10 00 00 00 00 26d+05:48:29.345 READ LOG EXT 61 00 10 ff ff ff 4f 00 26d+05:48:25.559 WRITE FPDMA QUEUED 60 00 08 ff ff ff 4f 00 26d+05:48:25.557 READ FPDMA QUEUED Error 10 occurred at disk power-on lifetime: 5717 hours (238 days + 5 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: WP at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 61 00 10 ff ff ff 4f 00 26d+05:48:25.559 WRITE FPDMA QUEUED 60 00 08 ff ff ff 4f 00 26d+05:48:25.557 READ FPDMA QUEUED 2f 00 01 10 00 00 00 00 26d+05:48:25.307 READ LOG EXT 61 00 10 ff ff ff 4f 00 26d+05:48:21.332 WRITE FPDMA QUEUED 61 00 18 ff ff ff 4f 00 26d+05:48:21.331 WRITE FPDMA QUEUED Error 9 occurred at disk power-on lifetime: 5717 hours (238 days + 5 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: WP at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 61 00 10 ff ff ff 4f 00 26d+05:48:21.332 WRITE FPDMA QUEUED 61 00 18 ff ff ff 4f 00 26d+05:48:21.331 WRITE FPDMA QUEUED 61 00 58 ff ff ff 4f 00 26d+05:48:21.330 WRITE FPDMA QUEUED 61 00 d0 ff ff ff 4f 00 26d+05:48:21.329 WRITE FPDMA QUEUED 61 00 40 ff ff ff 4f 00 26d+05:48:21.327 WRITE FPDMA QUEUED Error 8 occurred at disk power-on lifetime: 5717 hours (238 days + 5 hours) When the command that caused the error occurred, the device was active or idle. After command completion occurred, registers were: ER ST SC SN CL CH DH -- -- -- -- -- -- -- 40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455 Commands leading to the command that caused the error were: CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name -- -- -- -- -- -- -- -- ---------------- -------------------- 60 00 08 ff ff ff 4f 00 26d+05:48:17.538 READ FPDMA QUEUED 60 00 08 ff ff ff 4f 00 26d+05:48:17.538 READ FPDMA QUEUED 60 00 08 ff ff ff 4f 00 26d+05:48:17.536 READ FPDMA QUEUED 60 00 08 ff ff ff 4f 00 26d+05:48:17.535 READ FPDMA QUEUED 60 00 08 ff ff ff 4f 00 26d+05:48:17.534 READ FPDMA QUEUED SMART Self-test log structure revision number 1 No self-tests have been logged. [To run self-tests, use: smartctl -t] SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE amd64] (local build) Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org === START OF INFORMATION SECTION === Model Family: Seagate Barracuda 7200.14 (AF) Device Model: ST1000DM003-1SB102 Serial Number: Z9AX6NK2 LU WWN Device Id: 5 000c50 0b29f19ab Firmware Version: HPH4 User Capacity: 1,000,204,886,016 bytes [1.00 TB] Sector Sizes: 512 bytes logical, 4096 bytes physical Rotation Rate: 7200 rpm Form Factor: 3.5 inches Device is: In smartctl database [for details use: -P show] ATA Version is: ACS-3 T13/2161-D revision 3b SATA Version is: SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s) Local Time is: Tue Aug 16 09:59:53 2022 BST SMART support is: Available - device has SMART capability. SMART support is: Enabled === START OF READ SMART DATA SECTION === SMART overall-health self-assessment test result: PASSED General SMART Values: Offline data collection status: (0x82) Offline data collection activity was completed without error. Auto Offline Data Collection: Enabled. Self-test execution status: ( 0) The previous self-test routine completed without error or no self-test has ever been run. Total time to complete Offline data collection: ( 575) seconds. Offline data collection capabilities: (0x5b) SMART execute Offline immediate. Auto Offline data collection on/off support. Suspend Offline collection upon new command. Offline surface scan supported. Self-test supported. No Conveyance Self-test supported. Selective Self-test supported. SMART capabilities: (0x0003) Saves SMART data before entering power-saving mode. Supports SMART auto save timer. Error logging capability: (0x01) Error logging supported. General Purpose Logging supported. Short self-test routine recommended polling time: ( 2) minutes. Extended self-test routine recommended polling time: ( 105) minutes. SCT capabilities: (0x10bd) SCT Status supported. SCT Error Recovery Control supported. SCT Feature Control supported. SCT Data Table supported. SMART Attributes Data Structure revision number: 32 Vendor Specific SMART Attributes with Thresholds: ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE 1 Raw_Read_Error_Rate 0x002f 075 063 006 Pre-fail Always - 37534792 3 Spin_Up_Time 0x0023 097 097 000 Pre-fail Always - 0 4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 83 5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0 7 Seek_Error_Rate 0x002f 081 060 030 Pre-fail Always - 132729781 9 Power_On_Hours 0x0032 090 090 000 Old_age Always - 9491 10 Spin_Retry_Count 0x0033 100 100 097 Pre-fail Always - 0 12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 83 180 Unknown_HDD_Attribute 0x002a 100 100 000 Old_age Always - 1684849827 183 Runtime_Bad_Block 0x0032 100 100 000 Old_age Always - 0 184 End-to-End_Error 0x0033 100 100 097 Pre-fail Always - 0 187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0 188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0 0 0 189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0 190 Airflow_Temperature_Cel 0x0022 064 060 040 Old_age Always - 36 (Min/Max 33/38) 193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 474 194 Temperature_Celsius 0x0022 036 018 000 Old_age Always - 36 (0 18 0 0 0) 195 Hardware_ECC_Recovered 0x003a 029 012 000 Old_age Always - 37534792 196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0 197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0 198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0 199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0 SMART Error Log Version: 1 No Errors Logged SMART Self-test log structure revision number 1 Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error # 1 Short offline Completed without error 00% 1 - SMART Selective self-test log data structure revision number 1 SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS 1 0 0 Not_testing 2 0 0 Not_testing
