thedirtmerchant
- Jun 26, 2012
Is this a problem? Not really sure what happened. My NAS went down (nothing available) so I restarted. The below Alert is what I saw when I logged into the GUI
The volume Data1 (ZFS) status is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.Determine if the device needs to be replaced, and clear the errors using 'zpool clear' or replace the device with 'zpool replace'.
Not sure what/how to check.
I ran smartctl -a /dev/ada0 and got:
2 3TB drives in RAID1
8 GB RAM, FreeNAS 9.2.1.3 x64
Error 2 occurred at disk power-on lifetime: 22338 hours (930 days + 18 hours)
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 00 ff ff ff 4f 00 41d+06:05:47.039 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 41d+06:05:46.973 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 41d+06:05:46.972 READ FPDMA QUEUED
Error 1 occurred at disk power-on lifetime: 22334 hours (930 days + 14 hours)
60 00 00 ff ff ff 4f 00 41d+02:52:33.738 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 41d+02:52:32.264 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 41d+02:52:32.244 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 41d+02:52:32.243 READ FPDMA QUEUED
60 00 00 ff ff ff 4f 00 41d+02:52:32.242 READ FPDMA QUEUED
# 1 Short offline Completed: read failure 90% 14164 149884
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
If Selective self-test is pending on power-up, resume after 0 minute delay. 2 3TB drives in RAID1
