8 Offline uncorrectable sectors / 8 Currently unreadable (pending) sectors
So, Ive had this issue since the drive was installed and sort of just ignored it... but, trying to tackle this so I can clear the log message... (The NAS stores ONLY Videos ... TV Shows and Movies so isn't critical in any way, feel free to skip the lecture on using a drive with a SMART error)... Anyway.... I have the following error in FreeNAS:
  • CRITICAL: Aug. 19, 2017, 12:55 p.m. - Device: /dev/ada2, 8 Currently unreadable (pending) sectors
  • CRITICAL: Aug. 19, 2017, 12:55 p.m. - Device: /dev/ada2, 8 Offline uncorrectable sectors
I have tried running smartctl to read where the errors are and force their move with dd to the specific sector... But it seems from the log that all 8 errors are the same sector (is this possible?) and the error count doesn't go down (nor has it ever gone up to be fair)... Does anyone know what might be the issue with this drive not letting me force a bad sector move?
Attached below is the output of smartctl -a /dev/ada2 (this is reading in the middle of a long test):
% sudo smartctl -a /dev/ada2
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:	 Seagate Desktop HDD.15
Device Model:	 ST5000DM000-1FK178
Serial Number:	W4J17D9Y
LU WWN Device Id: 5 000c50 0906a07fd
Firmware Version: CC49
User Capacity:	5,000,981,078,016 bytes [5.00 TB]
Sector Sizes:	 512 bytes logical, 4096 bytes physical
Rotation Rate:	5980 rpm
Device is:		In smartctl database [for details use: -P show]
ATA Version is:   ACS-2, ACS-3 T13/2161-D revision 3b
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 3.0 Gb/s)
Local Time is:	Sun Aug 20 04:03:48 2017 PDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82)	Offline data collection activity
					was completed without error.
Self-test execution status:	  ( 248)	Self-test routine in progress...
					80% of test remaining.
data collection:		 (   96) seconds.
capabilities:			 (0x7b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:			(0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:		(0x01)	Error logging supported.
Short self-test routine
recommended polling time:	 (   1) minutes.
Extended self-test routine
recommended polling time:	 ( 615) minutes.
Conveyance self-test routine
recommended polling time:	 (   2) minutes.
SCT capabilities:		   (0x3035)	SCT Status supported.
					SCT Data Table supported.
ID# ATTRIBUTE_NAME		  FLAG	 VALUE WORST THRESH TYPE	  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate	 0x000f   112   097   006	Pre-fail  Always	   -	   45372328
  3 Spin_Up_Time			0x0003   092   091   000	Pre-fail  Always	   -	   0
  4 Start_Stop_Count		0x0032   100   100   020	Old_age   Always	   -	   415
  5 Reallocated_Sector_Ct   0x0033   100   100   010	Pre-fail  Always	   -	   0
  7 Seek_Error_Rate		 0x000f   082   060   030	Pre-fail  Always	   -	   8945321617
  9 Power_On_Hours		  0x0032   087   087   000	Old_age   Always	   -	   11744
10 Spin_Retry_Count		0x0013   100   100   097	Pre-fail  Always	   -	   0
12 Power_Cycle_Count	   0x0032   100   100   020	Old_age   Always	   -	   415
183 Runtime_Bad_Block	   0x0032   100   100   000	Old_age   Always	   -	   0
184 End-to-End_Error		0x0032   100   100   099	Old_age   Always	   -	   0
187 Reported_Uncorrect	  0x0032   040   040   000	Old_age   Always	   -	   60
188 Command_Timeout		 0x0032   100   100   000	Old_age   Always	   -	   0 0 0
189 High_Fly_Writes		 0x003a   100   100   000	Old_age   Always	   -	   0
190 Airflow_Temperature_Cel 0x0022   064   055   045	Old_age   Always	   -	   36 (Min/Max 33/37)
191 G-Sense_Error_Rate	  0x0032   100   100   000	Old_age   Always	   -	   0
192 Power-Off_Retract_Count 0x0032   100   100   000	Old_age   Always	   -	   386
193 Load_Cycle_Count		0x0032   100   100   000	Old_age   Always	   -	   523
194 Temperature_Celsius	 0x0022   036   045   000	Old_age   Always	   -	   36 (0 16 0 0 0)
195 Hardware_ECC_Recovered  0x001a   112   100   000	Old_age   Always	   -	   45372328
197 Current_Pending_Sector  0x0012   100   100   000	Old_age   Always	   -	   8
198 Offline_Uncorrectable   0x0010   100   100   000	Old_age   Offline	  -	   8
199 UDMA_CRC_Error_Count	0x003e   200   200   000	Old_age   Always	   -	   0
240 Head_Flying_Hours	   0x0000   100   253   000	Old_age   Offline	  -	   11739h+17m+11.114s
241 Total_LBAs_Written	  0x0000   100   253   000	Old_age   Offline	  -	   36827315422
242 Total_LBAs_Read		 0x0000   100   253   000	Old_age   Offline	  -	   122627591389
SMART Error Log Version: 1
ATA Error Count: 56 (device log contains only the most recent five errors)
	CR = Command Register [HEX]
	FR = Features Register [HEX]
	ER = Error register [HEX]
	ST = Status register [HEX]
Error 56 occurred at disk power-on lifetime: 11159 hours (464 days + 23 hours)
  ER ST SC SN CL CH DH
  40 51 00 ff ff ff 0f  Error: UNC at LBA = 0x0fffffff = 268435455
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  25 00 c0 ff ff ff 4f 00   5d+12:50:49.531  READ DMA EXT
  25 00 c0 ff ff ff 4f 00   5d+12:50:49.522  READ DMA EXT
  25 00 c0 ff ff ff 4f 00   5d+12:50:49.471  READ DMA EXT
  25 00 c0 ff ff ff 4f 00   5d+12:50:49.461  READ DMA EXT
  25 00 c0 ff ff ff 4f 00   5d+12:50:49.445  READ DMA EXT
Error 55 occurred at disk power-on lifetime: 11159 hours (464 days + 23 hours)
  25 00 08 ff ff ff 4f 00   5d+12:50:49.427  READ DMA EXT
Error 54 occurred at disk power-on lifetime: 11159 hours (464 days + 23 hours)
  ca 00 10 90 02 40 e0 00   5d+12:50:49.415  WRITE DMA
Error 53 occurred at disk power-on lifetime: 11159 hours (464 days + 23 hours)
  35 00 10 ff ff ff 4f 00   5d+12:50:49.411  WRITE DMA EXT
Error 52 occurred at disk power-on lifetime: 11159 hours (464 days + 23 hours)
Num  Test_Description	Status				  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Extended offline	Self-test routine in progress 80%	 11744		 -
# 2  Extended offline	Completed without error	   00%	 11048		 -
	1		0		0  Not_testing
	2		0		0  Not_testing
	3		0		0  Not_testing
	4		0		0  Not_testing
	5		0		0  Not_testing
joeschmuck
Old Man
The log only shows the last 5 errors, it just does not show all 8 different sectors. You can try to force the bad sectors but I think you are better off running the Extended Test to completion and if it all passes, check those values again. Ensure you run the Extended test frequently, this may help to remap the data to a good sector and lock out the bad ones.
How exactly are you using the dd command (the exact string you are entering). And after you run the dd command are you running a scrub?
Have you looked at the Wiki page for S.M.A.R.T. ? It explains part of the answer you want.
EDIT: Also please put your data in code brackets. I fixed your posting so it looks proper and easier to read.
Thanks... Im not sure how to code bracket something (I figured it out :)... sorry. And yes, Im aware that the output only shows the last 5 errors.. I'm not sure how to view the other 3... figured they'd show up when I clear these 5 :)
The dd command I am running is:
"dd if=/dev/zero of=/dev/ada2 bs=512 count=1 seek=268435455"
I also tried: "dd if=/dev/zero of=/dev/ada2 bs=512 count=1 seek=268435455 conv=noerror,sync"
both of which return:
1+0 records in
1+0 records out
512 bytes transferred in 0.000244 secs (2094815 bytes/sec)
1+0 records in
1+0 records out
joeschmuck
Old Man
Nope, you will never see the other error messages, they scroll off as far as I know. The most recent 5 will always be there even if they clear.
Unfortunately you are writing zeros to the one sector which means you destroyed data which resided there, assuming there was data there and I suspect there was. Run a scrub after the Smart long/extended test has completed to repair the damage. If the test completed without error then you are temporarily in the clear.
Lets say your SMART test fails again at the same LBA and you want to try to remap this block out of the drive table. I would use the following command:
dd if=/dev/ada2 of=/dev/ada2 bs=16M
This would read all data on the hard drive (from end to end) and write it back to the hard drive, thus refreshing the data vice writing zeros.
I'm pretty sure you could do this as well but I have not tested it and if you did this, it's all on you for the outcome as this could screw up all your data on the hard drive:
dd if=/dev/ada2 skip=26843000 of=/dev/ada2 seek=26843000 bs=16M
I believe this command you would start the copying just before your suspect area and then continue copying the remainder of the drive. Again, use at your own risk and refer to the dd man page for more details.
However if you can do it I would run badblocks on the entire drive at least 2 times just to play it safe and if you find a problem spot, target that area with badblocks and run it 50 times if needed, just ensure you padd it well before the proble location and well after.
I'm not sure if you understand why a sector goes bad when you have a lot of hours on the hard drive, and you might know this but if you don't... Generally it's because the surface area has become damaged. This could have been due to a head crash or heat, or some surface defect and the think layer of film is peeling off. Typically the area affected gets worse over time. While I understand that your data is not important to you, you can expect this problem to get worse over time.
I had anticipate that this would get worse over time.. but the error popped up when the drive was brand new... never got worse, also never went away... I will look into bad blocks (I've used it before but its been YEARS since)... as for the time on the drives, they're only 20% fish into their expected lifetime... I think. (They're just over a year old...)
joeschmuck
Old Man
Well it should still be under warranty then and your error is covered. I'd RMA the drive to be honest. I don't know if Seagate does advanced RMAs like WD does, where you toss them your credit card in case you do not return the failed drive, they toss you a replacment drive immediately and you ship the failed drive back in the same box.
If you plan to keep the drive, I'd run badblock on it. This will force the remapping of the bad sectors. Here is a link for running badblocks.
UNFORTUUNATELY, Seagate won't warranty the drives... they were purchased as externally enclosed drives... save close to a grand vs buying the damned things as desktop drives... I didn't keep the enclosures. and Seagate won't do anything with the bare drive, it has to be in the original enclosure... on the upside... I DID buy it from Costco... so, they will take anything back.
joeschmuck
Old Man
If you are forced to retain the drive, at least you have something you can try. I'd also ensure you are running a SMART Long test weekly for a few months at least (I run mine weekly always) to ensure more failures do not occur and then since you have a 5TB drive, maybe relax that to once every 2 weeks for the long test.
Before the migration to a server machine (was running everything off of a dell SFF machine... kept killing power supplies)... Ihad the SMART tests running I think every 10 days... This is a dump from that old machine to a bunch of externals, move the 4x5TB drives to a better box, and dump back all the data... So, since I've only put 2TB back on the machine, I'm running bad blocks on all the drives since all the data is currently on other drives anyways...so, will revisit them in a day or two :)
joeschmuck
Old Man
Very good call and that is good luck to have the data already backed up.
NASbox
AFAIK CostCo is 90 Days for computer/electronic stuff, so if you are close to that move fast!
You might find this helpful: https://www.backblaze.com/blog/hard-drive-smart-stats/
Keep an eye on 187 Reported_Uncorrect if that increases, ditch the drive really quickly.
If it's stable, then you may get away with it.
Based on my experience, there is a reason why WD/HGST drives cost more... better quality, but no drive is perfect, and that's what backups are for.
Good luck.
Good luck.
Just looked... Costco now sells them for $114 ... Im comfortable paying that much for 5TB... And the new box has 5 SATA ports rather than the 4 I had had... I may just pick up 2... have a total of 25TB storage...
joeschmuck
Old Man
But you are using a non-NAS drive which was not designed for 24/7 operation. I'm sure you understand the risk so I won't pester you about it.
