winnielinnie
- Oct 22, 2019
One last possibility that I can think of. Did you ever "receive" a replication to this pool?
Even if you think you didn't or don't remember, doesn't hurt to check.
Try both commands:
If nothing was "received" to this pool, then my last guesses are:
Option 1 could be ruled out with another computer or keyboard, or just outright dismissed if you can clearly type in your passphrase into a text editor and it appears 100% correct. (Not to mention, you may not even be using any special characters.)
Option 2 has happened to me before. When I first created a passphrase (and even entered it twice), it was off by one character. I had been able to unlock it successfully because the way I type on a keyboard results in certain consistent "twitches" and "misses". This "twitch" became less prominent over time, and then when I revisited the encrypted container, I couldn't unlock it! (I opened up a text editor and quickly typed what I thought my passphase was over and over and over and over, allowing myself to be sloppy and make mistakes. It was from this "sloppy list" that I found the correct passphrase.)
Try both commands:
zpool history storage-pool | grep recv zpool history storage-pool | grep receive
- Issue with keyboard and/or special characters in the passphrase, in which your input is not being properly read
- You're mistyping your passphrase, even if by a single character
