SOLVED Critical SMART error. Should i change the drive?
hasirak
Hi. Today I awoke to an email where my FreeNAS box was telling me the following:
Device: /dev/ada2, Self-Test Log error count increased from 0 to 1
A short self-test was scheduled to run that night, so i assume that's what produced it.
By running "smartctl -a /dev/ada2" i found the following error:
Num  Test_Description  Status  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline  Completed: read failure  60%  9829  1565565648
I am not familiar with the different smart errors, so I was hoping somwbody could tell me the severity of this error.
Does it mean that there where a single bad sector at about 40% into the drive?
Should I order a new disk immediately, keep an eye on it, or ignore it?
My set-up is 6 3TB drives in a RAIDZ2 configuration.
Complete contents of "smartctl -a /dev/ada2" pasted below:
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p16 amd64] (local build)
Model Family:  Western Digital Red (AF)
Device Model:  WDC WD30EFRX-68EUZN0
Serial Number:  WD-WCC4N0869436
LU WWN Device Id: 5 0014ee 25f49b3b5
Firmware Version: 80.00A80
User Capacity:  3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:  512 bytes logical, 4096 bytes physical
Rotation Rate:  5400 rpm
Device is:  In smartctl database [for details use: -P show]
ATA Version is:  ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:  Thu Jul  2 09:23:53 2015 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
  was never started.
Self-test execution status:  ( 118) The previous self-test completed having
  the read element of the test failed.
data collection:  (39120) seconds.
capabilities:  (0x7b) SMART execute Offline immediate.
  command.
  Self-test supported.
SMART capabilities:  (0x0003) Saves SMART data before entering
  power-saving mode.
Error logging capability:  (0x01) Error logging supported.
Short self-test routine
recommended polling time:  (  2) minutes.
Extended self-test routine
recommended polling time:  ( 393) minutes.
Conveyance self-test routine
recommended polling time:  (  5) minutes.
SCT capabilities:  (0x703d) SCT Status supported.
  SCT Data Table supported.
ID# ATTRIBUTE_NAME  FLAG  VALUE WORST THRESH TYPE  UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate  0x002f  200  200  051  Pre-fail  Always  -  0
  3 Spin_Up_Time  0x0027  181  179  021  Pre-fail  Always  -  5916
  4 Start_Stop_Count  0x0032  100  100  000  Old_age  Always  -  42
  5 Reallocated_Sector_Ct  0x0033  200  200  140  Pre-fail  Always  -  0
  7 Seek_Error_Rate  0x002e  200  200  000  Old_age  Always  -  0
  9 Power_On_Hours  0x0032  087  087  000  Old_age  Always  -  9836
 10 Spin_Retry_Count  0x0032  100  253  000  Old_age  Always  -  0
 11 Calibration_Retry_Count 0x0032  100  253  000  Old_age  Always  -  0
 12 Power_Cycle_Count  0x0032  100  100  000  Old_age  Always  -  42
192 Power-Off_Retract_Count 0x0032  200  200  000  Old_age  Always  -  16
193 Load_Cycle_Count  0x0032  200  200  000  Old_age  Always  -  78
194 Temperature_Celsius  0x0022  117  111  000  Old_age  Always  -  33
196 Reallocated_Event_Count 0x0032  200  200  000  Old_age  Always  -  0
197 Current_Pending_Sector  0x0032  200  200  000  Old_age  Always  -  0
198 Offline_Uncorrectable  0x0030  100  253  000  Old_age  Offline  -  0
199 UDMA_CRC_Error_Count  0x0032  200  200  000  Old_age  Always  -  0
200 Multi_Zone_Error_Rate  0x0008  200  200  000  Old_age  Offline  -  0
SMART Error Log Version: 1
No Errors Logged
# 2  Short offline  Completed without error  00%  9781  -
# 3  Short offline  Completed without error  00%  9734  -
# 4  Short offline  Completed without error  00%  9687  -
# 5  Short offline  Completed without error  00%  9639  -
# 6  Extended offline  Completed without error  00%  9598  -
# 7  Short offline  Completed without error  00%  9543  -
# 8  Short offline  Completed without error  00%  9495  -
# 9  Short offline  Completed without error  00%  9447  -
#10  Short offline  Completed without error  00%  9399  -
#11  Short offline  Completed without error  00%  9351  -
#12  Short offline  Completed without error  00%  9303  -
#13  Extended offline  Completed without error  00%  9262  -
#14  Short offline  Completed without error  00%  9207  -
#15  Short offline  Completed without error  00%  9159  -
#16  Short offline  Completed without error  00%  9111  -
#17  Short offline  Completed without error  00%  9039  -
#18  Short offline  Completed without error  00%  8991  -
#19  Short offline  Completed without error  00%  8943  -
#20  Short offline  Completed without error  00%  8896  -
#21  Extended offline  Completed without error  00%  8855  -
  1  0  0  Not_testing
  2  0  0  Not_testing
  3  0  0  Not_testing
  4  0  0  Not_testing
  5  0  0  Not_testing
I'd recommend running the long test first--although the short test encountered an error, none of the attributes are indicating anything out of the ordinary. Once the long test completes, post the SMART data again. But expect that you'll need to replace the drive.
hasirak
Just started a long self test with:
smartctl -t long /dev/ada2
Or at least I think I did. I got this message:
=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Extended self-test routine immediately in off-line mode".
Drive command "Execute SMART Extended self-test routine immediately in off-line mode" successful.
Testing has begun.
Please wait 393 minutes for test to complete.
Test will complete after Thu Jul 2 21:48:52 201
Use smartctl -X to abort test
Usually the long self-test takes just under an hour for all the disks to complete.
So now I just wait for about an hour, and then run "smartctl -a /dev/ada2" again to see the results?
However, I'm not sure the test got started at all, because I can't see any increased activity on the graphs in the Reporting tab of the GUI.
Robert Trevellyan
Pony Wrangler
SMART tests are run by the disk firmware, so FreeNAS doesn't report disk activity for them.
hasirak
The long self-test should be finished by now.
Running "smartctl -a /dev/ada2" again gives:
Local Time is:    Thu Jul  2 22:28:31 2015 CEST
                                        was never started.
Self-test execution status:      ( 113) The previous self-test completed having
                                        command.
                                        power-saving mode.
  9 Power_On_Hours          0x0032   087   087   000    Old_age   Always       -       9849
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       1
No Errors Logged
# 1  Extended offline    Completed: read failure       10%      9849         1565565648
# 2  Short offline       Completed: read failure       60%      9829         1565565648
# 3  Short offline       Completed without error       00%      9781         -
# 4  Short offline       Completed without error       00%      9734         -
# 5  Short offline       Completed without error       00%      9687         -
# 6  Short offline       Completed without error       00%      9639         -
# 7  Extended offline    Completed without error       00%      9598         -
# 8  Short offline       Completed without error       00%      9543         -
# 9  Short offline       Completed without error       00%      9495         -
#10  Short offline       Completed without error       00%      9447         -
#11  Short offline       Completed without error       00%      9399         -
#12  Short offline       Completed without error       00%      9351         -
#13  Short offline       Completed without error       00%      9303         -
#14  Extended offline    Completed without error       00%      9262         -
#15  Short offline       Completed without error       00%      9207         -
#16  Short offline       Completed without error       00%      9159         -
#17  Short offline       Completed without error       00%      9111         -
#18  Short offline       Completed without error       00%      9039         -
#19  Short offline       Completed without error       00%      8991         -
#20  Short offline       Completed without error       00%      8943         -
#21  Short offline       Completed without error       00%      8896         -
To me it seems like the long self-test found the same error as the short self-test. So I guess it's all over for this drive then?
By the way, how do you guys usually go about the RMA in these cases? Do you provide the retailer with the SMART results?
Right, the drive is goner.
And this is the first drive I've seen where a short test actually found an error not previously found by a long test!
As for the RMA, if you can convince the retailer to replace the drive (that it failed the SMART tests should be enough), you'll probably get a new one. If you do it directly with WD, you might get a refurb.
Robert Trevellyan
Pony Wrangler
One option is the online form on wdc.com. If I recall correctly, in addition to the serial number, you have to enter the error code from their disk testing tool (Data Lifeguard Diagnostics), which is a free download. But it may be easier to call them, after all, one reason you bought WD Reds was for the 24/7 support line.
hasirak
Just started the RMA process. I went with the retailers online solution. I have used it once before on a laptop, and it was very professional. But it's probably going to take a couple of days, so it's really nice that RAIDZ2 can loose 2 drives.
Thank you all for your input, it is much appreciated.
joeschmuck
Old Man
It looks like you have had the drive for a while so I'm a bit surprised that the place you purchased the drive from will allow you to replace it, but I guess it depends on that company. If you can get a new drive that would be great.
As for leaving the FreeNAS system up and running, just pay attention to it. I'd run a scrub right now and if there is any data on the failing hard drive, it may relocate it on a good section of the hard drive. Of course, running a scrub will likely cause more damage to the failing hard drive as well and if there is data there, it may end up telling you that there is a drive issue.
