Could not import configuration from RC1 to build 7520
joeschmuck
Old Man
This may be premature but I was unable to upload my settings file created with 8.0.1-RC1 into the nightly build. I received the message the file was not compatible or corrupt (can't recall right now).
I will check this over the next several days, sometimes the nightly builds are not 100% compatible.
William Grzybowski
Be aware, nightly is another branch (trunk) compared to 8.0.1...
you cannot upgrade from nightly to RC1, and won't be able to upgrade from nightly to RC2 or 8.0.1-RELEASE
joeschmuck
Old Man
You know, for the past several months I've always done a clean install and never restored the previous config file. Now I know why I did it that way. Too bad it's not completely compatible but I can live with it.
