- May 28, 2011
I'd like to start by saying I'm upgrading my real FreeNAS box from 8.0.4 to 8.3.0-RC1. Signature show system configuration.
1) The first problem I have encountered is the CONSOLE screen hangs with the last message being "Starting cron." and does not go beyond that. The GUI operates so I was able to import my pool.
When using the GUI, I am unable to force a reboot or shutdown and I suspect it's tied to this problem.
Entering the "Shell" I was able to type "reboot" to force a reboot and the subsequent boot did not have the hangup as indicated above. BTW, this is a repeatable problem, meaning if I reset to default then the problem above occurs again.
2) I have a 32GB USB Flash drive which works and mounts fine under 8.0.4 yet it isn't mounted as a drive under 8.3.0-RC1. So it doesn't show up under /mnt at all but is attached to umass0.
After upgrading and even after restoring to factory defaults the USB flash drive is not mounted as a drive.
df reports this and I'm not sure where to go from here...
I'm still beating on this but any help would be appreciated. Oh, I've also wiped out the USB flash drive just to see what happens there.
UPDATE: Problem #1 went away when I removed the 32GB USB FLASH drive and started all over again, or should I say it has worked once now.
[root@freenas /mnt]# df Filesystem 512-blocks Used Avail Capacity Mounted on /dev/ufs/FreeNASs2a 1897806 775782 970200 44% / devfs 2 2 0 100% /dev /dev/md0 9327 6607 1974 77% /etc /dev/md1 1647 4 1512 0% /mnt /dev/md2 305583 37082 244055 13% /var /dev/ufs/FreeNASs4 40527 1278 36007 3% /data farm 6280132306 119656 6280012650 0% /mnt/farm farm/Madyson 6280012976 326 6280012650 0% /mnt/farm/Madyson farm/Mark 6283502278 3489628 6280012650 0% /mnt/farm/Mark farm/Rebecca 6407421639 127408989 6280012650 2% /mnt/farm/Rebecca farm/backups 9369321595 3089308945 6280012650 33% /mnt/farm/backups farm/ftp 20971520 6010707 14960813 29% /mnt/farm/ftp farm/main 6608608539 328595889 6280012650 5% /mnt/farm/main farm/movies 7490708680 1210696030 6280012650 16% /mnt/farm/movies farm/music 6318501142 38488492 6280012650 1% /mnt/farm/music farm/photos 6331125043 51112393 6280012650 1% /mnt/farm/photos
