after using it for several month without any issue, the emby gui responds with "connection refused". This problem just occurs with the emby plugin installation, not any other as plexmedia, nextcloud and so on. The issue also remained after a reinstall of the plugin and also a manual installation of emby in a manually created jail.How can I figure out what issue id causing the problem.
TrueNAS-12.0-U8.1
emby version 4.7.5.0
The manual installation based on this article and worked without (at least what I recognized) any errors
www.truenas.com
I am not looking for "The ONE thing" that solves the issue but also how to analyse what is causing troubles, e.g steps to check the webservers functionality itself
It is not a productvie installation just somethong I am playing around installed on an HP Microserver
Many thanks for your support
TrueNAS-12.0-U8.1
HOWTO: Manually install Emby in a standard JAIL
Hi, I had an issue with the emby-plugin as mentioned here. And since I couldn't solve it, and no FreeNAS developer/expert suggested where to look at in order to troubleshoot it :(.. I thought why not trying to manually install Emby in a standard jail? And it worked!! :D:D Anyway, here are the...
