ok try the following.
delete emby jail!
start from scratch:
open a shell, or use the shell tab:
type the follwoing and or copy and paste:
cd /tmp
wget https://raw.githubusercontent.com/bott0r/iocage-plugin-emby-beta/master/emby-server-beta.json
iocage fetch -P dhcp=on vnet=on bpf=yes -n emby-server-beta.json --branch 'master'
wait until emby jail is created check if you see the interface at the dhcp address.
open the shell again and type and post here the output
cd /mnt
ls -la
cd media1
ls -la
choose a folder in media1 (e.g. folder1 or movies1) and mount it into the jail by hand with
iocage fstab -a emby-server-beta60 /mnt/media1/movies1 /movies1 nullfs rw 0 0
