ivyfpop
- Jan 14, 2017
Hey all,
I use FreeNas 9.10 to host the newest version of SyncThing through the plugin system. Everything worked perfectly up until yesterday about mid-day. I did not change any settings to SyncThing or FreeNas relatively prior to this bug's occurance.
The bug: Whenever I try to ssh or access the web gui of any of the jails I get a "Connection Refused" error. I initially thought this was a SyncThing issue until I decided to test another plugin install. I installed two more plugins, which created two more jails, of different types, and both of them resulted in a "Connection refused" error.
I am new to FreeNas and SyncThing, and networking etc. in general. (Currently a second semester Computer Science major) So I will try my best to make it easier to solve my problem, but it might be best to cut me some slack if I missed something.
I can SSH into the FreeNas just fine and tinker around, as well as being able to use the "shell" button from the jails section to access the terminal of SyncThing. It seems as if the only issue is that the connection is being refused and SyncThing is functioning itself correctly.
Thanks,
Thanks,
