usbhid-ups Connection failure: Connection refused
Richard Durso
UPS: Tripp Lite SMART 1500LCDT USB
FreeNAS: 9.3-STABBLE-201508250051
I thought this was on the supported device list... off by 1 letter (SMART 1500LCD is on list). Naturally I tried some of the drivers anyway. The port looks fine:
# sbconfig | grep ugen0.4
ugen0.4: <TRIPP LITE UPS Tripp Lite> at usbus0, cfg=0 md=HOST spd=LOW (1.5Mbps) pwr=ON (100mA)
But I get a connection refused messages in the logs when I try to start the UPS service which seems odd.
Sep 10 19:57:38 freenas notifier: Starting nut_upslog.
Sep 10 19:57:38 freenas notifier: Warning: initial connect failed: Connection failure: Connection refused
Sep 10 19:57:39 freenas notifier: Stopping nut_upslog.
Sep 10 19:57:39 freenas notifier: Waiting for PIDS: 49900.
Sep 10 19:57:39 freenas notifier: Stopping nut_upsmon.
I get an email that simply states "COMMBAD - ups".
I tried all these drivers:
  • Tripp Lite UPS3 SMART 1500LCD (protocol 2009)
  • Tripp Lite UPS3 SMART 1500LCDXL (protocol 2012)
  • Tripp Lite UPS2 1500 LCD USB
  • Tripp Lite UPS1 SmartOnline (Tripplitesu)
I'm curious if I have something besides a driver problem with the "Connection refused" message.
SweetAndLow
Sweet'NASty
Try a generic usbhid driver?
Richard Durso
I didn't see anything in the drop down list as "generic". I saw some which started with "Various" but none of them referenced "usbhid". Is there something specific I should be looking for?
Tried changing port to "auto" since apparently you don't need to be specific with the usbhid-ups driver.
No matter what changes I make consistently get " Warning: initial connect failed: Connection failure: Connection refused".
Full log:
Sep 11 09:17:08 freenas notifier: nut not running? (check /var/db/nut/upsd.pid).
Sep 11 09:17:08 freenas notifier: nut_upsmon not running? (check /var/db/nut/upsmon.pid).
Sep 11 09:17:08 freenas notifier: nut_upslog not running? (check /var/db/nut/upslog.pid).
Sep 11 09:17:08 freenas notifier: Will not 'restart' nut because nut_enable is NO.
Sep 11 09:17:08 freenas notifier: Will not 'restart' nut_upsmon because nut_upsmon_enable is NO.
Sep 11 09:17:08 freenas notifier: Will not 'restart' nut_upslog because nut_upslog_enable is NO.
Sep 11 09:17:35 freenas notifier: Network UPS Tools - Generic HID driver 0.39 (2.7.3)
Sep 11 09:17:35 freenas notifier: USB communication driver 0.32
Sep 11 09:17:35 freenas notifier: No matching HID UPS found
Sep 11 09:17:35 freenas notifier: Driver failed to start (exit status=1)
Sep 11 09:17:35 freenas notifier: Network UPS Tools - UPS driver controller 2.7.3
Sep 11 09:17:35 freenas root: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut
Sep 11 09:17:35 freenas notifier: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut
Sep 11 09:17:35 freenas notifier: Starting nut_upsmon.
Sep 11 09:17:35 freenas notifier: kill: No such process
Sep 11 09:17:35 freenas notifier: UPS: ups (master) (power value 1)
Sep 11 09:17:35 freenas notifier: Using power down flag file /etc/killpower
Sep 11 09:17:35 freenas upsmon[8941]: UPS [ups]: connect failed: Connection failure: Connection refused
Sep 11 09:17:35 freenas upsmon[8941]: Communications with UPS ups lost
Broadcast Message from root@freenas.localdomain
  (no tty) at 9:17 EDT...
Sep 11 09:17:35 freenas notifier: Starting nut_upslog.
Sep 11 09:17:35 freenas notifier: Warning: initial connect failed: Connection failure: Connection refused
Sep 11 09:17:36 freenas notifier: Stopping nut_upslog.
Sep 11 09:17:36 freenas notifier: Waiting for PIDS: 8961.
Sep 11 09:17:37 freenas notifier: Stopping nut_upsmon.
Sep 11 09:18:00 freenas upsmon[8940]: upsmon parent: read
Sep 11 09:18:01 freenas notifier: Waiting for PIDS: 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941, 8941.
Sep 11 09:18:01 freenas notifier: nut not running? (check /var/db/nut/upsd.pid).
Richard Durso
BTW - The nightly freenas security report had a reference to the UPS. Include it here in case any of these numbers are useful:
ugen0.4: <Tripp Lite> at usbus0
uhid0: <Tripp Lite TRIPP LITE UPS, class 0/0, rev 1.10/0.02, addr 4> on usbus0
Richard Durso
1TrueStoney
This is the last in a long line of threads that end with ... no answers. Has anyone had this device working properly? Should I just send it back before it's too late?
BigDave
FreeNAS Enthusiast
This model is shown on their website and has over 130 reviews and no mention of FreeNAS in any of those posts.
That's usually not a good sign...
rudyamid
It's not working for me, and I'm on the latest freenas 12rc2.
I'm going to have to plug it back into Windows.
GrahamBB
I have the same issue, cannot get it to work :-(
