Savell Martin
- Jun 10, 2013
Hi guys.
I'm having an issue with getting FreeNAS to see my UPS.
It is a APC Smart-UPS SC 1500.
I have it connected via USB on ugen1.4.
I am running FreeNAS 9.2.1.8.
And using the APC ups 2 Smart USB driver (usbhid-ups)
And I am getting this error:
Can anyone help me get my UPS sorted?
Oct 10 00:13:45 freenas notifier: nut not running? (check /var/db/nut/upsd.pid). Oct 10 00:13:45 freenas notifier: nut_upsmon not running? (check /var/db/nut/upsmon.pid). Oct 10 00:13:45 freenas notifier: nut_upslog not running? (check /var/db/nut/upslog.pid). Oct 10 00:13:45 freenas notifier: nut not running? (check /var/db/nut/upsd.pid). Oct 10 00:13:45 freenas notifier: Network UPS Tools - Generic HID driver 0.38 (2.7.1) Oct 10 00:13:45 freenas notifier: USB communication driver 0.32 Oct 10 00:13:45 freenas notifier: No matching HID UPS found Oct 10 00:13:45 freenas notifier: Driver failed to start (exit status=1) Oct 10 00:13:45 freenas notifier: Network UPS Tools - UPS driver controller 2.7.1 Oct 10 00:13:45 freenas root: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut Oct 10 00:13:45 freenas notifier: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut Oct 10 00:13:45 freenas notifier: nut_upsmon not running? (check /var/db/nut/upsmon.pid). Oct 10 00:13:45 freenas notifier: Starting nut_upsmon. Oct 10 00:13:45 freenas notifier: kill: No such process Oct 10 00:13:45 freenas notifier: UPS: ups (master) (power value 1) Oct 10 00:13:45 freenas notifier: nut_upslog not running? (check /var/db/nut/upslog.pid). Oct 10 00:13:45 freenas notifier: Starting nut_upslog. Oct 10 00:13:45 freenas notifier: Warning: initial connect failed: Connection failure: Connection refused Oct 10 00:13:46 freenas notifier: Stopping nut_upslog. Oct 10 00:13:46 freenas notifier: Waiting for PIDS: 26783. Oct 10 00:13:46 freenas notifier: Stopping nut_upsmon. Oct 10 00:14:10 freenas upsmon[26754]: upsmon parent: read Oct 10 00:14:10 freenas notifier: Waiting for PIDS: 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755, 26755. Oct 10 00:14:10 freenas notifier: nut not running? (check /var/db/nut/upsd.pid).
