ethereal
- Sep 10, 2012
i tried to configure the ups in freenas but i couldn't see which port to use - i thought if i start the ups service before i did the configuration then the port might show up. when i tried to start the ups service i got the following errors.
Dec 21 16:10:04 freenas notifier: Can't start /usr/local/libexec/nut/(null): No such file or directory
Dec 21 16:10:04 freenas notifier: Network UPS Tools - UPS driver controller 2.7.3
Dec 21 16:10:04 freenas root: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut
Dec 21 16:10:04 freenas notifier: /usr/local/etc/rc.d/nut: WARNING: failed precmd routine for nut
Dec 21 16:10:04 freenas notifier: Starting nut_upsmon.
Dec 21 16:10:04 freenas notifier: fopen /var/db/nut/upsmon.pid: No such file or directory
Dec 21 16:10:04 freenas notifier: Unable to use old-style MONITOR line without a username
Dec 21 16:10:04 freenas notifier: Convert it and add a username to upsd.users - see the documentation
Dec 21 16:10:04 freenas notifier: Fatal error: unusable configuration
Dec 21 16:10:04 freenas notifier: Network UPS Tools upsmon 2.7.3
Dec 21 16:10:04 freenas root: /usr/local/etc/rc.d/nut_upsmon: WARNING: failed to start nut_upsmon
Dec 21 16:10:04 freenas notifier: /usr/local/etc/rc.d/nut_upsmon: WARNING: failed to start nut_upsmon
Dec 21 16:10:04 freenas notifier: Starting nut_upslog.
Dec 21 16:10:04 freenas notifier: Warning: initial connect failed: Connection failure: Connection refused
Dec 21 16:10:09 freenas notifier: Stopping nut_upslog.
Dec 21 16:10:09 freenas notifier: Waiting for PIDS: 6219.
Dec 21 16:10:09 freenas notifier: nut_upsmon not running? (check /var/db/nut/upsmon.pid).
Dec 21 16:10:09 freenas notifier: nut not running? (check /var/db/nut/upsd.pid).
i'd appreciate a little help because i have never used an ups before - never mind configuring freenas
a Christmas kiss to anybody who can help
