I recently had a failure of the boot drive of FreeNAS and had to reinstall it from scratch. The configuration of the machine was the following:
2x4TB - MIRROR, encrypted, "PRIVATE"
4x2TB - RAIDZ, not encrypted, "LIBRARY"
I was able to import the PRIVATE volume using the "Auto Import Volume" feature, however I am unable to import the LIBRARY volume. I've searched quite thoroughly on the internet but I can't seem to figure out anything that could help get the LIBRARY volume back. To my understanding, "zpool status" should at least show some information about the LIBRARY volume. The partitions are still there on the 2TB drives, so I should be able to get my data back somehow, right? Please see the output of a bunch of commands below.
Many thanks for any assistance you can offer,
ta2
ta2
[root@freenas] ~# gpart show
=>        34  7814037101  ada0  GPT  (3.7T)
          34          94        - free -  (47k)
        128    4194304    1  freebsd-swap  (2.0G)
    4194432  7809842696    2  freebsd-zfs  (3.7T)
  7814037128          7        - free -  (3.5k)
=>        34  7814037101  ada1  GPT  (3.7T)
=>        34  3907029101  ada2  GPT  (1.8T)
    4194432  3902834696    2  freebsd-zfs  (1.8T)
  3907029128          7        - free -  (3.5k)
=>        34  3907029101  ada3  GPT  (1.8T)
=>        34  3907029101  ada4  GPT  (1.8T)
=>        34  3907029101  ada5  GPT  (1.8T)
=>      63  15633345  da0  MBR  (7.5G)
        63  1930257    1  freebsd  [active]  (942M)
  1930320        63      - free -  (31k)
  1930383  1930257    2  freebsd  (942M)
  3860640      3024    3  freebsd  (1.5M)
  3863664    41328    4  freebsd  (20M)
  3904992  11728416      - free -  (5.6G)
=>      0  1930257  da0s1  BSD  (942M)
        0      16        - free -  (8.0k)
      16  1930241      1  !0  (942M)
[root@freenas] ~# gpart list Geom name: ada0 modified: false state: OK fwheads: 16 fwsectors: 63 last: 7814037134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada0p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: d4fbf549-d7d8-11e2-99f0-60a44cb2b110 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada0p2 Mediasize: 3998639460352 (3.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: d5185b73-d7d8-11e2-99f0-60a44cb2b110 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 3998639460352 offset: 2147549184 type: freebsd-zfs index: 2 end: 7814037127 start: 4194432 Consumers: 1. Name: ada0 Mediasize: 4000787030016 (3.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5 Geom name: ada1 modified: false state: OK fwheads: 16 fwsectors: 63 last: 7814037134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada1p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: d59085cd-d7d8-11e2-99f0-60a44cb2b110 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada1p2 Mediasize: 3998639460352 (3.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 rawuuid: d5af9f99-d7d8-11e2-99f0-60a44cb2b110 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 3998639460352 offset: 2147549184 type: freebsd-zfs index: 2 end: 7814037127 start: 4194432 Consumers: 1. Name: ada1 Mediasize: 4000787030016 (3.7T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r2w2e5 Geom name: ada2 modified: false state: OK fwheads: 16 fwsectors: 63 last: 3907029134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada2p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: 63467859-da3b-11e2-884a-60a44cb2b110 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada2p2 Mediasize: 1998251364352 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 63519af1-da3b-11e2-884a-60a44cb2b110 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251364352 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029127 start: 4194432 Consumers: 1. Name: ada2 Mediasize: 2000398934016 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 Geom name: ada3 modified: false state: OK fwheads: 16 fwsectors: 63 last: 3907029134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada3p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e1 rawuuid: 63af36d9-da3b-11e2-884a-60a44cb2b110 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada3p2 Mediasize: 1998251364352 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 63b9a22c-da3b-11e2-884a-60a44cb2b110 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251364352 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029127 start: 4194432 Consumers: 1. Name: ada3 Mediasize: 2000398934016 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r1w1e2 Geom name: ada4 modified: false state: OK fwheads: 16 fwsectors: 63 last: 3907029134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada4p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 64398cf4-da3b-11e2-884a-60a44cb2b110 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada4p2 Mediasize: 1998251364352 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 6444dc8c-da3b-11e2-884a-60a44cb2b110 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251364352 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029127 start: 4194432 Consumers: 1. Name: ada4 Mediasize: 2000398934016 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: ada5 modified: false state: OK fwheads: 16 fwsectors: 63 last: 3907029134 first: 34 entries: 128 scheme: GPT Providers: 1. Name: ada5p1 Mediasize: 2147483648 (2.0G) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 64ac4637-da3b-11e2-884a-60a44cb2b110 rawtype: 516e7cb5-6ecf-11d6-8ff8-00022d09712b label: (null) length: 2147483648 offset: 65536 type: freebsd-swap index: 1 end: 4194431 start: 128 2. Name: ada5p2 Mediasize: 1998251364352 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 rawuuid: 64b7e5e0-da3b-11e2-884a-60a44cb2b110 rawtype: 516e7cba-6ecf-11d6-8ff8-00022d09712b label: (null) length: 1998251364352 offset: 2147549184 type: freebsd-zfs index: 2 end: 3907029127 start: 4194432 Consumers: 1. Name: ada5 Mediasize: 2000398934016 (1.8T) Sectorsize: 512 Stripesize: 4096 Stripeoffset: 0 Mode: r0w0e0 Geom name: da0 modified: false state: OK fwheads: 255 fwsectors: 63 last: 15633407 first: 63 entries: 4 scheme: MBR Providers: 1. Name: da0s1 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r1w0e1 attrib: active rawtype: 165 length: 988291584 offset: 32256 type: freebsd index: 1 end: 1930319 start: 63 2. Name: da0s2 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 988356096 Mode: r0w0e0 rawtype: 165 length: 988291584 offset: 988356096 type: freebsd index: 2 end: 3860639 start: 1930383 3. Name: da0s3 Mediasize: 1548288 (1.5M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1976647680 Mode: r0w0e0 rawtype: 165 length: 1548288 offset: 1976647680 type: freebsd index: 3 end: 3863663 start: 3860640 4. Name: da0s4 Mediasize: 21159936 (20M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 1978195968 Mode: r1w1e2 rawtype: 165 length: 21159936 offset: 1978195968 type: freebsd index: 4 end: 3904991 start: 3863664 Consumers: 1. Name: da0 Mediasize: 8004304896 (7.5G) Sectorsize: 512 Mode: r2w1e4 Geom name: da0s1 modified: false state: OK fwheads: 255 fwsectors: 63 last: 1930256 first: 0 entries: 8 scheme: BSD Providers: 1. Name: da0s1a Mediasize: 988283392 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 40448 Mode: r1w0e1 rawtype: 0 length: 988283392 offset: 8192 type: !0 index: 1 end: 1930256 start: 16 Consumers: 1. Name: da0s1 Mediasize: 988291584 (942M) Sectorsize: 512 Stripesize: 0 Stripeoffset: 32256 Mode: r1w0e1
[root@freenas] ~# zpool list NAME SIZE ALLOC FREE CAP DEDUP HEALTH ALTROOT PRIVATE 3.62T 1.81T 1.81T 50% 1.00x ONLINE /mnt
[root@freenas] ~# zpool status
  pool: PRIVATE
state: ONLINE
  scan: scrub repaired 0 in 5h49m with 0 errors on Sun Feb 16 05:49:49 2014
        NAME                                                STATE    READ WRITE CKSUM
        PRIVATE                                            ONLINE      0    0    0
          mirror-0                                          ONLINE      0    0    0
            gptid/d5185b73-d7d8-11e2-99f0-60a44cb2b110.eli  ONLINE      0    0    0
            gptid/d5af9f99-d7d8-11e2-99f0-60a44cb2b110.eli  ONLINE      0    0    0
errors: No known data errors
